Old 11-12-2004, 03:50 PM
94sportsedan 94sportsedan is offline
Where are the tire pressure sensors???
Where are the sensors that monitor the tire pressure. I was going to swap my gtp rims for better newer style gt rims. Is the sensor part of the gtp rim or can it be transferred to a gt rim.
Old 11-12-2004, 03:57 PM
BIG-L's Avatar
BIG-L BIG-L is offline
The sensor is on the hub....dont worry,change away.
~Larry~
ClubGP Member 6530
Since 2001
Old 11-12-2004, 04:04 PM
How the hell does it know if there is air missing form the actual tire then if it's on the hub?? Don't know much about this system jsut upgraded from a GT to GTP today, it's a bit older than the GT but a hellof a lot faster.
Old 11-12-2004, 05:55 PM
BIG-L's Avatar
It has to do with tire rotation.
ClubGP Member 6530
Since 2001
Old 11-12-2004, 07:18 PM
dwalmop dwalmop is offline
Re: Where are the tire pressure sensors???
Yes, it does have to do with rotation. All the tires should be spinning at the same rate. If air is low in a tire, then it's a different diameter, thus making it rotate more times than the other 3 tires in a given distance.
Old 11-14-2004, 12:51 AM
Did it today, thanks for the quick Responses!!
Old 12-24-2004, 11:01 PM
lineguy lineguy is offline
Just wondering if my 2000 GP GT Would have tire pressure sensors.
Old 12-25-2004, 12:00 AM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
It has them. You can see it when it does the light test when you turn on your key.
Old 12-25-2004, 04:04 PM
Phoenix69 Phoenix69 is offline
My tire pressure light never came on and my tire pressure got down to 14psi, is it broken? worth fixing?
Old 12-26-2004, 08:13 PM
I dont think my car has it. My tire presure was down to about 12 in one tire, 20 in the other and the light didnt come on. Didnt see anything about it in the book about it.
