Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-11-2012, 11:53 PM
VGIZZO VGIZZO is offline
'93 Camry -V6 3VZ-FE - Compression test help
My repair manual states that I should remove all the spark plugs from the engine and have the engine at normal operating temperature before preforming a compression test. However, the last time I replaced my plugs, I had to remove the intake plenum to get them out. Shouldn't I have the intake plenum installed to do this test? Can I do a compression test with just the 3 spark plug holes in the front without removing the other plugs in the rear?
Thanks,
VG
Old 03-12-2012, 05:07 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: '93 Camry -V6 3VZ-FE - Compression test help
Yes, you can do a compression test with just the three plugs in front. The reason for removing all the plugs is to get the engine cranking at a standard speed, the max speed the starter will turn it. If your compression results are a little low, then this would be why. More importantly is the cylinder to cylinder variation. Of course, you can't test the rear cylinders with the plugs in....
The best procedure is to temporarily install the plenum after removing all the plugs. If you can't get to the rear holes with the plenum installed, then you have no choice.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
94 Camry V6 with OBD # P1705 help! Tuan Nguyen Camry/Camry Hybrid/Vista 1 12-20-2011 09:39 PM
96 Camry V6 1MZ-FE w/A541E A/T. Need parts list for replacing lockup solenoid? kevinb70 Camry/Camry Hybrid/Vista 0 07-27-2010 09:51 AM
93 Camry 3VZ-FE Sensor Identification septicdeath Camry/Camry Hybrid/Vista 4 03-27-2008 03:59 PM
93 Camry Wagon 3vz-fe idle problems CRXperiment Camry/Camry Hybrid/Vista 7 01-23-2007 03:24 PM
compression test??help paliagp Let's get Technical! 1 12-22-2004 11:22 PM
