Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 12-20-2011, 01:14 PM
Tuan Nguyen Tuan Nguyen is offline
Post 94 Camry V6 with OBD # P1705 help!
Hi Everyone,
I am a new member. My car has check engine ON with the code P1705, also when driving the O/D light on the dashboard keeps flashing. I searched online and know that is a malfunction of Clutch speed sensor. I want to fix it by myself because it is old car, and I am unemployed. Would someone show me where is the sensor located and how to test it. Thank you very much in advance.
Old 12-20-2011, 09:39 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 94 Camry V6 with OBD # P1705 help!
Download the repair manual here
Unzip the archive
Search the file "11-A541E Automatic Transaxle.pdf" for the terms "Direct Clutch Speed Sensor"
You will hopefully find all the information you need.
Good luck
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
need help with a project can u help squeak205 205 1 09-13-2007 10:27 AM
Need help with OBD code 141. spacemoose39 Impala | Impala SS 0 01-17-2006 05:58 PM
92 camry with no HEAT!! help ! deadring Camry/Camry Hybrid/Vista 1 02-02-2005 11:19 AM
Help with OBD research project gdennis Let's get Technical! 2 02-26-2004 12:55 PM
need help with obd code p01710 mressa 7 Series 0 11-08-2003 10:19 PM
