Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 03-03-2012, 04:51 PM
dan fitz dan fitz is offline
'89 302 engine if rotor spins is timing chain ok
hi, my manuals are all packed away for moving and i have an '89 E250 with a fuel injected 302 in it. it's not starting, cranks without firing up, died in the driveway a couple weeks ago. has over 300K miles on original engine and was wondering if maybe the timing chain broke, so with the cap off the distributor, the rotor is spinning when i crank it but i don't know if it's run off the crankshaft or the camshaft. i will get around to checking fuel pressure but of course my tester is packed away with the repair manuals....
Old 03-03-2012, 10:08 PM
mechhound mechhound is offline
Re: '89 302 engine if rotor spins is timing chain ok
If the rotor spins the timing chain is not broken. Yes the distributor drives off the camshaft.
Check to see if you have spark going through the spark plug wires while cranking the engine. I would guess the ignition module on the side of the distributor has gone dead.
GM 2.2L OHV DOHC: Interference or NON-Interference sharpnshine General Discussions 1 04-27-2009 08:21 PM
1990 f-150 302 change timing chain also? MERC_DoD F Series 1 10-05-2008 09:00 PM
Balancer chain and timing chain timing DunksAuto 9-3 0 02-11-2008 03:05 PM
Engine Bogging Down, Timing Chain Problem? Dyno247365 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 02-06-2006 04:40 PM
Engine lifting bracket/timing chain help please superfret78 Grand AM 1 03-14-2005 05:24 PM
