Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-08-2012, 06:14 AM
snorander's Avatar
snorander snorander is offline
2001 Grand Cherokee Limited intermittant starting problem
So my wife has a 2001 Jeep Grand Cherokee Limited with the 4.7L V8 it also has a Python remotoe starter. Recently the remote starter has stopped working and I am having intermittant starting problems with it. Sometimes when you put the key in and turn it you get nothing, maybe just a faint click no gauges etc. After fiddling with it for a while it will start up and run fine. Sometimes it starts fine with no problems at all. I assumed that the smart key was going bad so I had another one made(I needed a spare anyways). Unfortunately it does the same thing. So now I am wondering if there is something wrong with part the reads the smart key. When i get a chance I will dissconnect the remote starter so I can rule that out. Just wondering if anyone has seen or heard of this problem before and can point me in the right direction. I am desperately hoping to avoid the dealer.
Thanks,
Steve
Old 02-08-2012, 07:17 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 2001 Grand Cherokee Limited intermittant starting problem
Have your battery checked. I was having odd starting problems similar to yours, and the new battery fixed them all. Post back after it's tested and let us know...
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 02-08-2012, 08:43 PM
snorander's Avatar
Ok Problem solved! It turns out the negative battery terminal was cracked. It kind of all makes sense now. This problem started to show up about two weeks ago and as it happens two weeks ago I had the neg battery terminal disconnected to fix the broken blend door. So I am going to assume that it cracked when I was taking off then. Replaced the terminal tonight and it starts fine with both keys and even the remote start works fine now. Thanks for your help!
Old 02-08-2012, 09:10 PM
Score! I've seen many issues that were battery or battery cable related, especially in the colder months.
Glad you're back on the road.
2001 Grand Cherokee Limited - rear clunking over bumps jamx13 Grand Cherokee | Grand Cherokee SRT8 2 01-17-2010 04:48 PM
2001 Grand Cherokee Limited Won't Start Jeep_Doug Grand Cherokee | Grand Cherokee SRT8 7 01-30-2009 04:12 PM
2001 Grand Cherokee Limited info dss56 Grand Cherokee | Grand Cherokee SRT8 0 05-06-2008 10:53 AM
94 Grand Cherokee Limited, no start problem nick_n_ii Grand Cherokee | Grand Cherokee SRT8 2 02-24-2008 12:58 PM
1995 grand cherokee limited, no start and alarm? xkameroso Grand Cherokee | Grand Cherokee SRT8 14 12-28-2004 11:13 AM
