Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-20-2012, 11:34 PM
buddyochoa buddyochoa is offline
'98 Starting problem when warm
I have a 98 Bonneville naturally aspirated. When cold it starts up and runs perfectly. Once I shut it off and leave it for a bit, it takes a lot of cranking to get it to started again. After it does restart it usually runs rough for a bit, and sometimes will stall when letting off the gas within a few minutes of restarting it. After I drive for a bit it runs perfect until I shut it off again.
Old 01-21-2012, 03:21 PM
maxwedge maxwedge is offline
A990 racer
Re: '98 Starting problem when warm
Welcome to AF, check for raw fuel in the vacuum hose at the fp regulator on the fuel rail, post back, also when was the last time the throttle body was cleaned and are you loosing any coolant?
Old 01-21-2012, 03:28 PM
The throttle body has never been cleaned since i've owned it, but thats only been since July of 2011. I did have to add a bit of coolant, but again I don't know if it took a week or a year to loose that little bit since I didn't check when I bought the car.
It has 205,000 miles on it. Forgot to mention that, but thought i'd add just in case it was important.
Old 01-21-2012, 06:54 PM
Tech II Tech II is offline
Did you check the vac line like Max asked you to do?
Old 01-21-2012, 07:18 PM
Just removed the vacuum hose to the fuel pressure regulator. No fuel appears to be in the line, or leaking from the regulator. No noticeable change in the way the vehicle runs when removed either.
Old 01-23-2012, 08:24 AM
Jrs3800 Jrs3800 is offline
I think you need to check the actual fuel pressure ( 48-55 Psi )... I'd say either that Regulator is bad or the Pump is tired...
Old 01-25-2012, 09:58 AM
I did find out today I am loosing coolant. Can't see any smoke coming from the car though.
Old 01-25-2012, 07:44 PM
Well, if there are no external leaks, then the upper plenum is suspect......
02 Grand Am Hard Start when engine warm. ajbtrugreen Grand AM 3 08-01-2010 01:06 PM
bmw 318 1996, starting problem when warmed up lazyjane 3 Series 3 02-05-2009 03:52 PM
2001 Astro difficult starting when warm, OK on cold start?? dhspring M Bodies 10 09-22-2008 12:56 PM
Starting problems when car is warm... FoRCedInDuKsionGsT Eclipse Problem Diagnosis 2 12-27-2004 02:16 PM
88 caravan stall and start probs when warm dammpa Caravan | Voyager 9 01-31-2004 08:26 AM
