Old 08-19-2008, 07:31 AM
dhspring dhspring is offline
2001 Astro difficult starting when warm, OK on cold start??
Anyone experienced a difficult start on their Astro when the engine is warm? I have 102,000 miles and it runs great otherwise. It starts right up on cold start but when warm you have to hold the starter on for a few seconds to get her running. This is exactly like my other cars/truck when I had a bad fuel pressure regulator, when I changed that, problem was solved, only those have port fuel injection unlike the Astro. My Astro doesn't have an external fuel pressure regulator since it has throttle body injection, unlike the others that have port injection and pressure regulator on the fuel rail.
I'm thinking it's a fuel issue, I have checked the fuel pump pressure and it's good at about 50 lbs., have put new plugs, wires, dist cap and rotor on in the last year so I'm thinking it's something on the throttle body injection system. Any help is greatly appreciated so I don't have to visit the local Chevy Stealership.
Old 08-19-2008, 10:50 AM
CD Smalley CD Smalley is offline
Re: 2001 Astro difficult starting when warm, OK on cold start??
50 PSI is not good enough. It needs to be closer 60 PSI I believe.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 08-19-2008, 11:03 AM
Yeah, 50 is probably not the right number, I'm sure I checked with the Chilton book when I tested it to make sure I had the correct number, I'm pretty sure the fuel pump is okay.
Can someone tell me how to do the fuel leakoff test? And what are the poppets some other post referred to as being a probable cause?
Old 08-19-2008, 11:37 AM
brcidd's Avatar
brcidd brcidd is offline
see if this helps-- this van was "hard to start" as well -- because it was always flooded
http://www.automotiveforums.com/vbul...ght=documented
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 08-19-2008, 03:38 PM
Leeann94astro's Avatar
Leeann94astro Leeann94astro is offline
You don't have throttle body injection; you have sequential port fuel injection that's located under the intake manifold. It has poppet valves (one for each cylinder) and a fuel pressure regulator as a unit (kinda looks like a spider, hence the name).
I don't know what the fuel pressure is supposed to be on an '01, but it's something like 62 psi...but don't quote me on that.
Old 08-19-2008, 06:25 PM
Again, 50 PSI is NOT ENOUGH. Search here. OldMaster has posted the exact figure. I think it does have to be 62 as Leeann stated above. That figure does ring a bell.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 08-20-2008, 09:53 AM
Correct, I checked the Haynes book, the required fuel pressure is 55 to 64 psi depending on CSFI or CMFI but that checked out okay, otherwise it would not start cold either, I will recheck to be sure, but I'm thinking it's the fuel pressure regulator causing the problem, just checked with the dealer, it's $100, man, expensive critter.
Old 08-20-2008, 10:17 AM
brcidd's Avatar
I'd make sure you don't have a leak, and that your fuel pump is capable of 62 psi before changing out a regulator- you can pinch off the return line to prove out fuel pump- a leak would show up in leak down test with fuel pressure gage attached- as in the video link I sent you.
'99 GMC Yukon
Old 08-20-2008, 10:29 AM
Thanks brcidd, will do. How difficult is it to change the fuel press regulator? It looks pretty simple from the Haynes book, is it plug and play, i.e. there are no settings or adjustments correct, you just bolt it in and go?
Old 09-20-2008, 10:07 PM
homedesigns homedesigns is offline
We focusing to much on fuel, how about our temperture sensors, have you got access to a scanner. I would check my ECT and IAT they are always suppose to be about the same temp give or take 10 degrees
Old 09-22-2008, 12:56 PM
Thanks for the tip homedesign, I will check it out. It is not my fuel pump, I have 59-60 psi there, still might be the press. regulator but you have to take off the intake manifold to get to it, which I'm not going to do, right away. Hopefully it is something simpler as you have suggested.
