Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 02-04-2009, 12:32 PM
lazyjane lazyjane is offline
bmw 318 1996, starting problem when warmed up
hi fellas, my lovely bmw will turnover and start everytime from cold or if its been left standing for a couple of hours . But if i then switch off engine after running it for 15minutes or so and try to start it wont turnover at all, i can hear the starter whizzin' round. what going on?
Old 02-04-2009, 12:44 PM
Re: bmw 318 1996, starting problem when warmed up
when i run engine for 5 minutes,switch off, then restart its fine------its just when i run it for longer thats when the starter whizzes
Old 02-05-2009, 03:10 PM
Broken-wrench Broken-wrench is offline
I had a real weird problem with an old Audi~ wouldn't run when it was dark. After fiddling around with things , I discovered that-after the ambient air temperature fell below 90F ( I live in Phoenix, Az. and this happened in the summer when daytime highs reach 115F), it quit. Turned out to be a fuel pump relay that didn't like it below 90F!! I believe that you have something that doesn't like to start when the engine temp is hot. Don't know enough about the system off hand to point you in the right direction but I think it is a temperqture related problem.
Old 02-05-2009, 03:52 PM
thanks broken-wrench, i think your right, it is temperature related but i have no idea what is causing it not to start when warm!
