Old 12-31-2011, 03:30 PM
cruiser69 cruiser69 is offline
Car Will Not Stay Started
I have an 02 3.8 GT with 95k on it. Has been driving fine and then out today and suddenly it will not stay started unless my foot is on the gas. It was fun getting it back home that way. I have cleaned IAC valve and cleaned MAF. I also unplugged MAF to see if it stayed started and it did not. I also tried a spare MAF sensor I have and that did not changed anything either. Fuel pressure regulator not leaking gas so I do not think it is that it was replaced last February. I replaced fuel filter about 11 months ago so I do not know if that could be the problem or maybe fuel pump. What should my next step be. Thanks for any help.
Old 12-31-2011, 08:13 PM
rickisrad rickisrad is offline
Re: Car Will Not Stay Started
clean the throttle body out very well. That will usually cure it. any other symptoms?
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 12-31-2011, 11:12 PM
What is the best way to clean the throttle body. Do you need to remove it?
Old 01-01-2012, 05:19 PM
I cleaned the throttle body and it did not fix the problem. Could it be the TPS or MAP sensor? I have not replaced either of these yet on the car.
Old 01-01-2012, 08:15 PM
Tech II Tech II is offline
Check for a vac leak....check vac line to the fuel pressure regulator for fuel....with snorkle removed, have someone start the vehicle and spray carb cleaner into intake.....if it runs as long as you spray, fuel problem...either pressure or delivery(injectors)...
have you checked for codes?
Old 01-01-2012, 10:39 PM
grease_monkey1975's Avatar
grease_monkey1975 grease_monkey1975 is offline
I agree with everything tech II said, check fuel issue with some carb spray and look for vac leaks! Is the check engine light on? Also can you check fuel pressure? Pump maybe going bad
Old 01-02-2012, 11:43 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
With the car off, unplug the MAF sensor and then start it to see if the car stays running. If it does, regardless if there is a code or not, it's bad and needs replacing.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 01-04-2012, 03:59 PM
The IAC was bad again. Replaced it and I am back in business. Thanks for the help.
96 windstar turns over but will not stay started!! penguin87 Windstar 2 06-21-2007 11:31 AM
88 Cherokee will not stay started jeeper186 Cherokee 2 01-05-2007 09:43 PM
help ! my car will not stay started wedo Caprice 1 02-08-2005 09:07 PM
97 JGC Will Not Stay Started Unless Giving Gas bigro_tx Grand Cherokee | Grand Cherokee SRT8 3 11-02-2004 03:44 PM
My 1996 Grand Am will not stay started!! kellimoore Grand AM 4 09-13-2003 12:04 PM
