Old 11-16-2011, 12:25 PM
99kylegtp 99kylegtp is offline
a/c belt
hey i got a 99 gtp and my a/c is going out ..is there a way to bypass it without buying a bypass pully and if so what size belt would i need thanks AF..
Old 11-16-2011, 08:42 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: a/c belt
Welcome to AF!!
Unless the compressor locks up and doesn't turn there really isn't any reason to remove it just leave it where it is and use the belt you have.
Old 11-17-2011, 08:21 AM
Re: a/c belt
its starting to sound like the bearing is going out thou..
Old 11-17-2011, 09:09 AM
Pontiac Guy
Re: a/c belt
The only way you can eliminate the compressor is to use a bypass pulley if compressor is going bad and needs to be removed. You may be better off to get a used compressor from a wrecking yard and get it recharged.
The Following User Says Thank You to GTP Dad For This Useful Post:
99kylegtp (11-17-2011)
Old 11-17-2011, 12:22 PM
Re: a/c belt
ya my comp just locked up so ima run the bypass till it starts getting warm , then ill put a new one on and pull a vacume an charge it...i got my master EPA so i can do it..thanks for the help
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
limousime 1.9 TDI 1999 ventilator belt noise kmiki '97+ 0 04-20-2009 02:40 AM
99' Ram Quad Cab -I Need Seat belt Help PLEASE!! nrosssr Ram Pickup | Ram SRT10 0 03-30-2009 05:42 PM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
How to Tighten Tensioner on Serpentine Belt - 05 G6 donnap1957 G6 0 02-26-2009 09:01 PM
