Old 11-02-2011, 07:18 PM
jeffv jeffv is offline
Angry blower motorproblems
i have a 97 grandprix where the blower motor only runs on 5, replaced the resistor, wiring harness and motor. and same results..... anyone else had this problem?
Old 11-03-2011, 08:31 AM
Tech II Tech II is offline
Re: blower motorproblems
Sounds like the blower switch in the control head..... can confirm with test light.....disconnect the harness to the resistor block.....key on, engine off.....turn the blower switch to position #1......one of the circuits in the harness should be hot.....change position to #2....another circuit should be hot and so on.......if no power in any circuit in the first four speeds, double check the low speed fuse.....if ok, than check for power into the head...if ok, then it's the switch in the head....don't know if just the switch can be replaced or if the whole head has to be replaced....
Old 11-03-2011, 10:17 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Are you having any other electrical gremlins such as the key not coming out, instrument cluster lights dropping, shifter not going into/coming out of park, etc...? If so, you may have a failing ignition switch, a common issue on these cars.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 11-03-2011, 06:08 PM
ya, rear defog doesnt work, check tire pressure light stays on. little things like that. gonna change the ignition this weekend. thanks
Old 11-03-2011, 06:09 PM
ya checked it all, power on all settings. gonna change the ignition switch. hopefully that does it.
Old 11-03-2011, 07:15 PM
"ya checked it all, power on all settings. gonna change the ignition switch. hopefully that does it. "
Wait a minute, you had power on all 5 positions at the harness?
Old 11-04-2011, 09:03 PM
yes i did
Old 11-04-2011, 09:26 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Sounds like you're onto something with the ignition switch.
Old 11-04-2011, 10:10 PM
i think so to, i priced one out for 265 bucks... yikes! might have to stick with only speed 5 through the winter
Old 11-05-2011, 08:54 AM
aleekat aleekat is offline
Just did a quick search on Rockauto.com anywhere from $70 to $110
Old 11-05-2011, 09:11 AM
Guys, re-read.....he says he has power at all 5 position at the harness to the resistor block.....
Old 11-07-2011, 05:16 PM
yes i see... thanks alot! but how am i supposed to know what one fits the car... there are like 6 different ones?
90 Astro Van Blower Fan/Blower not working larch303 M Bodies 1 01-07-2006 08:46 AM
Heater blower and a/c blower problem scotty47 Escort 5 11-05-2005 07:13 PM
Proper fuse for Blower Motor Control Module and Blower Fan Clay_Bee Park Avenue 4 10-15-2004 10:44 PM
heater blower/ac blower newscarver Aurora 3 10-08-2004 04:33 PM
a/c blower switch or blower motor? Aggrev8ed GTP Ownr Grand Prix 5 06-28-2004 10:35 PM
