Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 10-03-2004, 07:02 AM
newscarver newscarver is offline
heater blower/ac blower
this is a new problem often the blower doesnt work on start up but it will start blowing after a few minutes...or it wont blow at all during the trip....i have a hunch it may have somthing to do with the heat or humidity in the car when you first get in it...because if you put down all the windows and open the sunroof ,this is when it begins to blow
Old 10-03-2004, 03:02 PM
Retro-D Retro-D is offline
Re: heater blower/ac blower
I had the same thing happen about a month ago. It turned out to be a corroded lead feeding the blower control module. The module is located inside the car under the passenger side dash. Part of the module is inside the housing near the blower motor. Mine got so bad you could smell the plastic burning as the connection arced.
Old 10-08-2004, 03:56 PM
thanks for the tip it was a corroded connection at the fan motor...a few wiggles and it started working, there sure is alot of other stuff in there that needs explaining...news
Old 10-08-2004, 04:33 PM
Re: Re: heater blower/ac blower
Your very welcome! There appears to be a design flaw with some of the connectors in the heater fan area. I think it's caused by galvanic corrosion, anyway good to hear you found the problem, save the $$ for the gas tank.
