Old 10-07-2011, 08:46 AM
1heyboer 1heyboer is offline
Too much oil?
Hello. 93 with a non-supercharge. Changed the oil, and filter. Added 5 quarts. Looks high on the dipstick. Added 5, I think, at last change also. Does this car only take 4 quarts? Have i hurt anything? Should I drain a quart? Do anything else?
Thanks.
Old 10-07-2011, 07:44 PM
diesel1962 diesel1962 is offline
Re: Too much oil?
I think the engine takes only 4.2 qts of oil.Used to own a Olds 88 royal,1994.Drain one qt out and check dip stick. Have a good day! Diesel1962
Old 10-07-2011, 08:05 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Too much oil?
Yeah, they're right about 4.5qts.
Old 10-07-2011, 10:18 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Too much oil?
No need to drain anything, an additional 1/2 qt will not hurt anything.
Old 10-11-2011, 09:28 AM
Re: Too much oil?
Thanks
Old 10-11-2011, 05:24 PM
Jrs3800 Jrs3800 is offline
Re: Too much oil?
Agreed... I generally run all of my 3800's at 5 qts...
What are the symptoms of adding too much oil to your car?? Patrix Integra 9 01-17-2011 05:06 PM
Too Much Oil Given in an Oil Change Lois215 General Discussion 1 05-17-2008 04:08 PM
Oil leak, possibly from too much oil? Kearsed Camry/Camry Hybrid/Vista 2 03-13-2007 04:43 PM
too much oil? whitGSR07 Integra 2 02-26-2005 12:38 PM
Will too much oil cause the engine to knock? 92VR4Red Camaro Discussions 3 07-26-2004 04:41 PM
