Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-07-2003, 05:09 PM
Patrix Patrix is offline
Send a message via AIM to Patrix
Question What are the symptoms of adding too much oil to your car??
Newbie to cars here.
I think I added too much oil to my integra. when I start it up the tail pipe bellows out smoke and the car barely revs. Will this damage anything? How many quarts and what kind should I use for my next oil change?
Thanks!
Old 11-07-2003, 07:08 PM
michael1686 michael1686 is offline
Did you try checking the dipstick
Old 11-07-2003, 09:01 PM
Re: What are the symptoms of adding too much oil to your car??
yes I did. The oil level was way too high. I am going to drain it down to a normal level then let the car idle and burn whatever oil is stuck in the system. Will this be harmful to the car? I don't know what else to do
Old 11-07-2003, 09:15 PM
shaunthebadass shaunthebadass is offline
Send a message via AIM to shaunthebadass
yeah dude you might want to drop that oil line down a little......not good to have the oil level up around the combustion chamber.....might catch your whole engine on fire or screw up your piston and what not
Old 11-09-2003, 12:03 AM
cyphate cyphate is offline
how long have you been driving with too much oil?
you might want to check your spark plugs also just in case there is damage from the high oil level.
Old 11-09-2003, 09:25 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Drain it out ,then fill it with the right amount, 3.8qts I think, then run the motor for a few mins. Then replace your plugs and see how it runs.
Old 01-16-2011, 09:40 PM
enginegasmotorelec enginegasmotorelec is offline
Wink Re: What are the symptoms of adding too much oil to your car??
u can't damage your spark plugs you can just foul them, if this happens you will have a misfire and just need to take out the plugs and clean them with a dry rag. also if you drove it for a while with high oil you might have cut down the life of your catalytic converter, if an engine light goes off it'll be your oxygen sensor post cat. other major problems you can get will be results of your pistons going up and down splashing the oil as they hit bdc (bottom dead center). all you have to do is open the drain plug at the bottom for a second not even all the way, drain oil (not into environment ) get out from under the car and check ur dipstick til its in the proper range. dont waste money on new oil.
Old 01-16-2011, 09:42 PM
his car runs with an engine not a motor, Tesla runs on motors
Old 01-16-2011, 09:47 PM
oil doesn't burn, nether does gas if its not compressed and heated to vaporized ideal mixture ratio is 14.7:1 air to fuel or 1 atmosphere, nothing is gonna light on fire
Old 01-17-2011, 05:06 PM
BullShifter's Avatar
Look up the definition! There is no need to post on a thread that died in 2003!
–noun
1.
a comparatively small and powerful engine, esp. an internal-combustion engine in an automobile, motorboat, or the like.
2.
any self-powered vehicle.
3.
a person or thing that imparts motion, esp. a contrivance, as a steam engine, that receives and modifies energy from some natural source in order to utilize it in driving machinery.
4.
Also called electric motor. Electricity . a machine that converts electrical energy into mechanical energy, as an induction motor.
5.
motors, stocks or bonds in automobile companies.
–adjective
6.
pertaining to or operated by a motor.
7.
of, for, by, or pertaining to motor vehicles: motor freight.
8.
designed or for automobiles, their drivers, or their passengers: The hotel has a motor lobby in its parking garage for picking up and discharging passengers.
9.
causing or producing motion.
10.
Physiology . conveying an impulse that results or tends to result in motion, as a nerve.
11.
Psychology, Physiology . Also, motoric. of, pertaining to, or involving muscular movement: a motor response; motor images.
–verb (used without object)
12.
to ride or travel in an automobile; drive: They motored up the coast.
–verb (used with object)
13.
Chiefly British . to drive or transport by car: He motored his son to school.
The Following User Says Thank You to BullShifter For This Useful Post:
khanguyen519 (06-25-2011)
What are the symptoms of a bad coil? 1998z Cavalier Problem Diagnosis 9 11-24-2005 11:01 PM
What are the symptoms of a bad EGR valve? 1998z Cavalier Problem Diagnosis 0 05-27-2005 09:16 AM
What are the symptoms of a bad diff? Budanam 4Runner/GX470 3 01-31-2005 01:47 PM
What are the symptoms of a plugged EGR ? TonyMazz Blazer 1 12-02-2004 09:55 PM
what are the symptoms of a bad fuel pump? homeslice2284 Escort 1 11-07-2004 05:45 AM
