Old 07-22-2004, 04:02 PM
92VR4Red's Avatar
92VR4Red 92VR4Red is offline
Will too much oil cause the engine to knock?
my engine on my step dads fire bird is knocking... and we where messing around with it and when we checked the oil it lookedto be 2 or 3 qrts too high... would that be the problem??
Old 07-22-2004, 04:30 PM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
Uhhhh, 2 or 3 quarts? Yea, something is going to happen, if not just a mess.
Old 07-26-2004, 05:35 AM
SphinXX SphinXX is offline
Banned
No, 3 quarts will not cause the engine to knock. Depending on the engine and oil pan size most engines will run with that much over. Some if over filled simply will not start. Having that much over in oil will only cause the oil pressure to build so high that you will start to blow seal through out your engine, thus needing the engine to be pulled out and torn down. Might as well rebuild it since you are doing that.
Old 07-26-2004, 04:41 PM
Maifirehawk Maifirehawk is offline
Re: Will too much oil cause the engine to knock?
Too much oil will make the engine sounds like knock, the Rod Journals hit the oil and making knocking sound, not to mention the fact that it will making air pockets (bubbles) in your bushings and cause the engine to Overheat.
Mai
