Go Back   Automotive Forums Car Chat > Chrysler > Pacifica
Old 09-20-2011, 08:57 PM
KyooMac KyooMac is offline
Radiator fans not working.
I have a 2005 Pacifica, my wife had the upper radiator hose blow off last Thursday, and overheat, she pulled over and I went out to her location to see what may be wrong. I put the hose back on and filled it with water, everything appeared fine and we drove the last five miles home. It appears to be the radiator cap was bad, so I replaced it. It has not overheated since.
My question is this, I've been watching the fans and the car to see if it'll overheat again and it has not. But I have not seen the radiator fans come on at all. If I turn on the AC they come on, but if I turn off the AC the fans stop working. I have driven it around and have not heard them come on. Is it a faulty coolant temperature sensor? Or does the engine have to get really hot for the fans to come on? I seem to remember the fan coming on when one turns the car off, but since the radiator hose incident it has not. Since it is not my daily driver, I am not sure on that.
Old 09-20-2011, 09:25 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Re: Radiator fans not working.
One of the fans come on when ever the A/C is being used. This is to pull air past the air conditioners (smaller) radiator. The other fan is temperature activated. If that one does not come on then you may have a problem. Some cars with small inefficient radiators will have the fan cycle on and off with the car just idling every 2 or three minutes. Case in point...Honda Accords and Civics. At idle...those fans turn on and off every couple of minutes. However, I used to have Camaro IROC Z and those fans hardly EVER came on. But the IROC was programmed by the factory to operate at higher engine temps to help clean up the tail pipe emissions.
Did you ever notice the fans turning on and off before the engine overheated (besides when the a/c was used. I would suggest however that you atleast replace the thermostat and add the proper amount of engine coolant to the cooling system. All that heat and pressure probably didn't do any good for it.
The Following User Says Thank You to Tony Silva For This Useful Post:
KyooMac (09-20-2011)
Old 09-20-2011, 09:32 PM
I never noticed the fans come on before, it's not my daily driver, but my wife's. Just like I posted, I vaguely remember them coming on when the car was turned off. I'll be replacing the thermostat tomorrow, and the coolant sensor, just to be safe. And of course adding the right mix of coolant. Thanks for your quick reply.
1998 Pontiac Trans Sport radiator fans only work when the AC is turned on amikayla Montana/Montana SV6 1 06-01-2010 12:25 PM
Radiator fan not working danjag1 Grand AM 1 06-24-2005 11:25 AM
'91 Cav 2.2 60k, Radiator fan not working, what are these plugs? salesmunn Cavalier 4 04-28-2005 11:15 AM
Radiator fan not working 99 Taurus dbully Taurus | Taurus Wagon 3 11-26-2004 12:51 PM
1997 Escort Radiator Fan Not Working yoo-hoo Escort 1 10-18-2004 10:35 PM
