Old 04-26-2005, 12:08 AM
salesmunn salesmunn is offline
Thumbs up '91 Cav 2.2 60k, Radiator fan not working, what are these plugs?
Hey guys! You've been great help in the past, now I need your expertise one more time! (well, at least one more.)
I had my radiator replaced recently and since then, my car would slowly overheat if I was stuck in traffic. It would cool down, however, if I was moving. I realized pretty quickly that my radiator cooling fan wasn't kicking on to cool my engine.
I removed the fan and tested the connectors directly to the battery and it worked fine. Now I just want to make sure the sensor or switch is working to turn it on. Unfortunately, I'm not sure where the sensor is and the best way to test it.
There are 2 little plugs in the side of the engine, shown within the white square in this picture. Note that I've blown the image up a bit in the bottom-right so you could see the plugs/switches.
What those two plugs? I think the bottom one is the temperature gauge, because if I test that to the battery my temp gauge goes haywire in the car. I'm not sure what the plug above it does, is that the gauge for the radiator fan?
What are these two plugs?
Thanks for the help. Summer is coming and it would help to have this fan working. New York traffic sucks.
Old 04-26-2005, 01:32 AM
deadBird's Avatar
deadBird deadBird is offline
Re: '91 Cav 2.2 60k, Radiator fan not working, what are these plugs?
Try again with them pics man.
From the sounds of it, yer testing your ECT. It jumping all around is what is does when it is bad. If your car heats up while sitting in traffic and cools down while moving, and the gauge shows this, then your ECT is fine.
If your fan comes on when you wire it directly, then you more than likely just need to replace the relay.
Old 04-27-2005, 11:06 AM
Re: Re: '91 Cav 2.2 60k, Radiator fan not working, what are these plugs?
Bah, lemme try again. Looking at the top plug. If that IS the relay, how would I test to see if it's bad?
http://us.f3.yahoofs.com/users/4224d...5w7bCBwRZcHoXT
Old 04-27-2005, 01:47 PM
deadBird's Avatar
You can't link directly to your yahoo mail.
http://www.imageshack.ws/
The relay is in the fuse box, and it's a square. Besides that, check the 30amp fuse for the fan.
Old 04-28-2005, 11:15 AM
Re: Re: Re: '91 Cav 2.2 60k, Radiator fan not working, what are these plugs?
Ah, I'm having trouble linking from my Yahoo album. Sorry about that.
Oh okay, so it's in my fuse box? That's definitely not where I thought it was. Thanks.
