Old 09-08-2011, 02:53 PM
Zonic2001's Avatar
Zonic2001 Zonic2001 is offline
Question about Cleaning Excess CA off PE Parts
I have two PE parts glued on top of each other (they compliment each other) and I have very small glue run off that occured when I placed the top PE over the base PE. This small run I know is there and is bothering me also, I know that a judge with a magnifying glass will see it. What can I do to remove this excess CA glue without hurting the PE surfaces nor the bonding? The CA is already cured.
Old 09-08-2011, 03:50 PM
Plumberboy Plumberboy is offline
Re: Question about Cleaning Excess CA off PE Parts
I think there is a product that will unglue CA glue. You might try putting a little of it on one of those miniature pointy Q-tips and slowly melt it off without scratching the PE surface by rubbing it back and forth.
Old 09-08-2011, 03:59 PM
Zonic2001's Avatar
Did that before and unglued both parts
Old 09-08-2011, 04:49 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
Post some pics. It will be easier to give advice if we can see what you're talking about.
PHOTOBUCKET SUCKS
Old 09-08-2011, 05:16 PM
Zonic2001's Avatar
Is a hassle to get HD pictures on a small piece of PE part that doesn't measure more than a couple of mm.
Is simple, think of a PE part in a form of a washer. Then, the second PE is a smaller diameter washer glued on top of the bigger one. Between the two pieces the glue ran out off the pieces and you can see it. How can I remove the excess CA? Excess CA ran out off between the two pieces, both pieces are PE (metal). No resin parts here.
Old 09-08-2011, 05:34 PM
MPWR's Avatar
I would scrape it off with a sharpened toothpick.
PHOTOBUCKET SUCKS
Old 09-08-2011, 06:55 PM
kadler18's Avatar
kadler18 kadler18 is offline
AF - Old Man
Use Acetone on a q-tip. Acetone slowly desolves dried CA.
Old 09-08-2011, 07:08 PM
Helico's Avatar
Helico Helico is offline
>95% Isopropanol worked for me.
Old 09-09-2011, 09:42 AM
Zonic2001's Avatar
Great suggestions!
But last night I used a toothpick and the solution that dissolves CA... it worked perfectly. I used a couple of toothpicks tho... it seems that the solution softens the wood (specially the sharp tip of the toothpick), strange but true. Anyway, it took several passes with the toothpick but took it out. I noticed no discoloration on the metal finishing. Just wanted let others know.
Thanks guys for the other alternatives. Will keep them in mind.
i got a question about my bravada, aftermarket parts like cold air intakes and drop k fallenhonda General Discussion 0 07-25-2007 05:48 PM
question about ABS / TCS OFF light error pointatob Grand Prix 2 04-10-2007 11:36 AM
Yet another question about cleaning the EGR valve Fluvannahoo Rodeo | Passport | MU 5 06-30-2006 01:53 PM
question about injector cleaning before swap gsf1200m '88 - '91 Civic | CRX | Wagon | Shuttlee 0 08-19-2003 10:36 AM
