Old 08-26-2011, 07:59 PM
teegolf teegolf is offline
97 Lumina ABS Light On
Have a 97 Lumina with 3.1 engine. ABS light stays on solid. Any idea what to look for or will a code reader give me a code? Brakes seem to function OK.
Thanks,
Old 08-26-2011, 10:02 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 97 Lumina ABS Light On
Yes, need to start with a code, several things can set the light. Post the codes. You will have normal base brakes with abs lamp on, just abs will be inop.
Old 08-27-2011, 03:54 PM
maxwedge maxwedge is offline
A990 racer
You need access to a scanner that is set up for abs codes.
Old 08-28-2011, 09:21 AM
Tech II Tech II is offline
My local AutoZone has a scanner that reads ABS codes....they do it for free.....
Basically, it will point you in the direction of a particular wheel.....all you can do is make a visual inspection.....might find a damaged harness or sensor....disconnect harness and look for water intrusion(sometimes,in this case, you will need harness and sensor).....
do you have a multimeter? If yes, you can check ohm rating of sensor, and also A/C output of the sensor when spinning the wheel....
If sensor, it's the WHOLE hub/bearing....
Old 08-28-2011, 12:01 PM
A990 racer
AZ cannot or will not do abs scans here in NYS.
Old 08-28-2011, 05:22 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
On my '97 the reluctor ring is pressed onto the hub, but the sensor is separate...you'd have to take the top 2 hub bearing bolts out to replace it, but no need to replace the hub unless the reluctor is missing a tooth or something...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 11-20-2011, 02:14 PM
Update on my question. Have pulled all wheels and inspected sensors, wires, and notched wheel on hubs. Cannot detect anything wrong. Went to Auto zone and their code reader will not pull ABS codes. Went to O'Reily and they said as long as car was 1996 or newer their code reader would work. Connected code reader and it said vehicle was not equipped to for ABS codes. Tried mutiple times and got same result. Did a little more surfing on the internet and it appears that maybe there is some software that only GM dealers have to read the ABS codes. Can anyone confirm if this is true I have to go to a dealer or offer advice to for next steps to take?
Thanks!
Old 11-20-2011, 06:29 PM
A990 racer
Any professional high line scanner, not AZ or O'reilly's will read codes, Actron makes one about 350.00 or pay a shop for the code and diagnosis. The Snap On MTG has full ABS diagnostics also.
93 Lumina ABS Light rebelvance Lumina 5 05-25-2009 07:37 AM
1997 chevy lumina abs light is on cfrank2 Lumina 5 10-25-2008 02:39 PM
97 Lumina ABS light BostonKev Lumina 2 04-20-2006 04:22 PM
3.1 98 lumina ABS light battlechaser1212 Lumina 7 08-15-2004 05:44 PM
'98 Lumina ABS Light On! citpaj Lumina 2 07-06-2003 04:14 PM
