Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-09-2011, 09:12 AM
akubacki akubacki is offline
Gauges stopped working 1997 GS-t Spyder
All my gauges except my fuel gauge stopped working. Even the cigarette lighter-used to peower my external XM unit has no power.
What can cause this and how do I fix it?
1997 Mutsubishi Eclipse GS-T Spyder.
Old 08-11-2011, 11:14 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Gauges stopped working 1997 GS-t Spyder
Welcome to AF!
Check your fuses under the dash for anything blown. The cig lighter is on its own and shouldn't affest the dash lights. Those are on another circuit. But a short could have caused both to pop. Check those and replace if needed.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-11-2011, 11:52 AM
That was it! Blown Fuse. The dealer wanted to replace the alternator!!!
My local mechanic replace the fuse and all was good.
THANK YOU!
Old 08-11-2011, 02:08 PM
david-b's Avatar
Dave is THAT guy
THANK YOU!
The alternator? Wow... how did he figure that one out? Just wow.
Well, glad it was something easy!
75 Monte Carlo
Old 08-11-2011, 06:57 PM
ned032002's Avatar
ned032002 ned032002 is offline
The question is, what caused the fuse to pop?
Old 08-12-2011, 08:53 AM
david-b's Avatar
Dave is THAT guy
Good follow up question. If the fuse pops, something caused it to. What? And why? On older cars they had fuseable links which were basically just smaller gauge wire. I blew one on my Monte last week, for no reason at all. Turned out wire was just old and almost rotting away.
However, new fuses really don't do that ever. Has the car been worked on before this happened? New radio? Does the battery drain at all?
75 Monte Carlo
Old 08-14-2011, 03:12 PM
FUSE BLEW again. Its a 1o amp fuse on the under dash fuse box labeled INST.
It happened the fist time when I punched the accelerator to the floor to avoid a collision. It happened again yestesday when a friend took is out for a fun ride--How can you not "try to see what is the acceleration" on a car like this?
What's causing the instrument fuse to pop when the accelerator is punched?
Old 08-17-2011, 01:29 PM
It was the Alternator! I have no idea how a bad alternator caused one fuse to continually pop, but it did.
Old 08-18-2011, 11:17 AM
ned032002's Avatar
Way weird. Well, at least its fixed now.
Old 08-18-2011, 12:48 PM
david-b's Avatar
Dave is THAT guy
That doesn't make sense. Only way I could see that happening is if the alternator was putting out more power than it's supposed to, and that never happens. Too little power won't cause it to pop.
75 Monte Carlo
Old 08-19-2011, 09:22 AM
ned032002's Avatar
When my alternator went to shit on my DSM, it was charging at 16v. I thought my battery was going to pop.
Old 08-20-2011, 06:08 PM
david-b's Avatar
Dave is THAT guy
Very weird. I guess it happens more often than I thought.
75 Monte Carlo
Old 08-20-2011, 08:02 PM
ned032002's Avatar
Scared the crap out of me. I was scared to pop the hood!
1997 grand am gauges stopped working lowside Grand AM 3 03-19-2008 01:24 PM
Dashboard -speedo, tach, HUD, and gas gauges stopped working! help plz twstice Grand Prix 14 04-25-2004 10:45 PM
My gauges stopped working Paonessa Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 7 10-05-2003 04:41 PM
Rpm gauge stop working 91BLKsi '88 - '91 Civic | CRX | Wagon | Shuttlee 4 03-08-2003 09:57 PM
Boost gauge stops working ! r33gts25t Performance 1 01-14-2002 01:14 AM
Tags
gauges
