Go Back   Automotive Forums Car Chat > Cars in General
Old 06-28-2011, 12:41 PM
AF News Desk's Avatar
AF News Desk AF News Desk is offline
Your Source For Auto News
Post Getting Good Mileage? Think Again.
A recent study completed by Edmunds has discovered that fuel efficiency readings on vehicles via gauges or listed on sale sheets may actually be misleading or downright incorrect.
According to the report, two tests completed in seven vehicles yielded results that suggest an overestimation of fuel efficiency as high as 19 percent, which in a car that might get 30 miles per gallon (mpg), would mean a difference of nearly 6 mpg (or, 24 mpg instead of the 30).
The report from Edmunds.com:
Originally Posted by Philip Reed, Edmunds - 5/12/11
As gas prices rise, drivers are paying closer attention to the fuel economy gauges that are found in most late-model cars as part of the trip computer. The only problem is that the gauges are inaccurate. In fact, Edmunds testing reveals that one such gauge claimed fuel economy 19 percent higher than the actual result.
Across two tests in seven different vehicles, the gauges were 5.5 percent inaccurate on average, according to data gathered by the editors at Edmunds.com.
The editors noted such optimistic estimates from fuel economy gauges during our 2009 and 2010 "Fuel-Sipper Smackdown." In two separate tests, editors drove five fuel-efficient cars from Los Angeles to Las Vegas and back under three different driving conditions: back roads (45-60 mph), city streets (stop and go) and highway (70-75 mph). During the tests (a total distance of more than 1,550 miles was accumulated by each car), the editors measured fuel economy by calculating how much gas was required to go a certain distance and comparing that to the reading on the fuel economy gauge.
Gauges Come Standard — and Skew High
Fuel economy gauges, which show both average and current fuel economy, are standard equipment in 92 percent of 2011 vehicles, according to Edmunds data. By resetting the gauge when refueling, a driver sees what kind of fuel economy the vehicle delivers. Drivers can change their driving style and see if this improves fuel economy.
The individual inaccuracies in Edmunds testing were as high as 19 percent for the 2010 Ford Escape Hybrid and 16 percent for the diesel-powered 2010 Volkswagen Jetta SportWagen TDI. This means that the Escape was getting 5 mpg less than the gauge indicated, while the Jetta was getting 5.7 mpg less. The test also included a 2009 Mini Cooper, 2010 Ford Fusion Hybrid, 2010 Honda Insight, 2010 Toyota Prius, 2010 Toyota Highlander Hybrid, 2010 GMC Terrain and 2010 BMW X5 xDrive 35d.
A 5.5 percent error in a car's estimated fuel usage might not seem like a big deal over a single tank of gas, but over the typical five-year period of car ownership, it adds up. Take a car that shows 25 mpg on its fuel economy gauge, but which actually is consuming 5.5 percent more. Extend that over five years of driving at 15,000 miles per year and you get 132 gallons of unreported fuel use. That represents a substantial amount of money.
If a driver uses the fuel economy meter as the basis for budgeting, he would plan for five-year fuel costs of $12,000 (assuming fuel stays at $4 per gallon). In reality, the figure would be $12,660. The discrepancy is even larger for vehicles that have worse average fuel economy. The driver of an SUV or pickup that averages 12.5 mpg according to its fuel economy gauge might budget $24,000 for fuel. The actual cost would be $25,320 — a difference of $1,320.
But since our testing discovered that some fuel economy gauges are far more optimistic than the 5.5 percent average, some scenarios are even worse. It's entirely possible that our hypothetical 25 mpg car could consume 500 more gallons than predicted by the gauge over the typical five-year ownership period. That's $2,000, assuming $4-per-gallon gas. A thirstier truck or SUV might consume 1,000 additional gallons, adding up to $4,000 over five years. And, of course, it would be even more if the price of gas rises during that period.
The Manufacturers' Responses
Edmunds contacted all the manufacturers with vehicles represented in the two tests and asked for an explanation for these consistently overly optimistic fuel economy readings. A Ford spokesman replied that it was too difficult to find the right engineer to respond to this question. BMW and Volkswagen did not respond to requests from Edmunds.
Roger Clark, senior manager of GM's energy center, explains that the fuel economy gauge makes a calculation by counting the number and duration of pulses made by the fuel injectors as they squirt gasoline into the combustion chambers of the engine. The onboard computer system divides the distance the car travels by this estimated fuel consumption.
Clark says the gauge is "dead nuts accurate" — if you consider all the variables at work during driving, including temperature, driving conditions and driving style. The biggest fluctuation occurs because ethanol, which is blended with gasoline in varying amounts, contains less energy.
"When you fill up, you are paying for a gallon of gas, but the energy in that gas varies significantly," Clark says. This means that while the car's computer assumes the gasoline is providing energy to drive a certain distance, the fuel might have less energy and not propel the car as far.
The 5.5 percent average variation in the vehicles Edmunds tested "seems like a perfectly reasonable range to me," says Paul Williamsen, national manager of the Lexus College, where his responsibilities include service training for Lexus staff, dealers and corporate personnel. "I can't imagine any reason that any automaker would want to make drivers think they can get better fuel economy than they were getting," Williamsen adds.
Honda spokesman Chris Martin wouldn't comment on the accuracy of Honda gauges, saying he needed to do more research to give a good answer. However, he defends fuel economy gauges in general, and says that people should use them as "a driving-efficiency tool, not a precise measurement of fuel economy."
The gauges make their point best when they utilize symbols rather than numbers, Martin says. Many new Honda models have gauges that display color changes to reflect how efficiently someone is driving. This method is more effective at helping drivers learn to drive efficiently than is other feedback that might require more attention to understand, he says.
Mini's gauges are "very accurate" because they use real-time information, says Mini Product Manager Vinnie Kung. However, he adds that inaccuracies can come from such factors as fuels and even fuel tanks, which expand during warm weather. For instance, Kung notes that in the summer a Mini might be able to hold 14 gallons of fuel in a tank whose labeled capacity is 13.2 gallons. In the winter, it might only hold 12.9 gallons. This variation affects a variety of readings, including mpg and the "distance to empty" reading that shows how much range is left.
Don't Rely on the Readings
Steve Mazor, chief auto engineer for the Auto Club of Southern California, has a different explanation for the consistently high readings for the fuel economy gauges. The gauge "assumes it is a perfectly operating vehicle — and it isn't." For example, he says fuel injectors can become clogged and not deliver as much fuel as the gauge assumes.
Mazor certainly doesn't see any conspiracy by automakers to mislead the public with consistently high numbers, but says of the gauges: "We tell people not to trust them except as a comparative tool." In other words, a driver could use the gauge to see differences produced by changing his or her driving style.
Dan Edmunds, director of vehicle testing for Edmunds.com, thinks there's a better way to express the variations in fuel economy. He believes that rather than consistently present a best-case mpg figure to drivers, the calculations that power the gauge readout should incorporate some of the variables noted by the experts above. That's better than presenting drivers with "figures that are never under and always over" the actual fuel economy, he says.
And despite protestations to the contrary, Dan Edmunds says there is an incentive for carmakers to present overly optimistic mpg feedback to their customers. "Because window sticker ratings and mpg advertising claims are hard to match in real life, fuel economy is one of those things that is often ranked 'below expectations' on owner feedback surveys like J.D. Power's Initial Quality Survey," he says.
Whatever the reason for their inaccuracies, it seems that fuel economy gauges should have this label: "Your actual mileage may vary." And Dan Edmunds recommends using a second source for recording fuel economy, such as joining Fuelly.com and logging every tank of gas to get a more accurate reading. But for the technologically challenged, he recommends a hands-on approach. "Grab a pen and paper, keep track of the data yourself and come up with your own numbers."
While this may surprise some, I can't say I'm all that surprised at all. With mandates coming down from the government on many manufacturers to make sure vehicles meet specific efficiency marks, it's hard to imagine some manufacturers NOT fudging the numbers by way of their equipment. After all, if it SAYS it gets so much per gallon, how could a few test drives disprove what engineers built to be correct? Then there's the "not an exact science" argument that one could apply to determining mpg. "Of course there will be some differences."
What do you think? Have you ever felt like your vehicle gets worse fuel efficiency than it actually says it does? What do you think about that feeling NOW?
Have a news tip/idea? Let us know!
Email [email protected] or send us a private message with a link to the content you think AF Members should check out!
The Following User Says Thank You to AF News Desk For This Useful Post:
Windshield Pros No (02-12-2012)
Old 06-28-2011, 02:03 PM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Re: Getting Good Mileage? Think Again.
I'm not surprised or shocked at a little fudging in the fuel economy #s. But then again, I check my gas mileage almost every tank. (Not to mention that I've never actually bought a new car to compare predictive figures to actual mileage)
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 06-28-2011, 07:36 PM
danielsatur danielsatur is offline
1) Log mileage on the odometer trip clock, after fill up.
2) Keep the receipt after fill up, it will help keeping records of gas being used in between fill ups.
3) Reset the odometer trip clock.
4) Try to keep RPM's around 2000 while driving.
The EPA rates my 2005 Mazda tribute 4 cylinder at 23mpg, I am getting around 30mpg.
Old 06-29-2011, 10:04 AM
Old Lar's Avatar
Old Lar Old Lar is offline
I manage to get more the the EPA listing on my stock cars. When I had my 99 Buick, it had an instant mpg guage on it and I learned how to drive using that as an indicator of "good" driving technique. I keep records of my mpg for all my cars.
My current car, an '06 HHR, has a rating of 25/30, but my average has been 30.6 mpg for the 82,000 miles I have now. My 87 Fiero GT with 135,000 miles i manafed to average 29.3 mpg this past month while on the Hot Rod Power Tour some 3300 miles. The car was only EPA rated at 28 mpg when new, for highway.
Old 06-29-2011, 10:35 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
This has always been pretty well known throughout people in the industry, you have to do your own calculations.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
The Following User Says Thank You to -Josh- For This Useful Post:
rumblinbumblin (07-03-2011)
Old 07-01-2011, 03:07 PM
Plumberboy Plumberboy is offline
http://kikerperformance.com/index.htm
I apologize ahead for posting this here but seemed a good place. I put these on a truck about four years ago. Honestly I don't check mileage but they made my old S10 run great. I have a 93 S10 that has over 279K on it. It is a 2.8 V6 with a 5 speed. Original engine and tranny.
Old 07-02-2011, 06:06 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
3) Keep the receipt after fill up, it will help keeping records of gas being used in between fill ups.
Yip, the only way to accurately measure fuel consumption is with steps 1-3.
As the article states, there are just to many variables to calculate while driving and any gauge should be used as an indication only.
That said, if you need a gauge to tell you how efficiently your driving you need a lesson in throttle control.
And you should apologise.
There are all sorts of devices that claim to do all sorts of things to improve gas mileage.
I have yet to see one that stood up to proper scientific investigation.
These magic wires are no different to all the other magic devices that are in reality just the modern version of snake oil cures.
Old 07-04-2011, 09:27 AM
I can only say that testimonial letters are kind of hard to overlook.
Old 07-04-2011, 04:56 PM
speediva's Avatar
We appreciate your enthusiasm, but all products have some fool who thinks their snake oil tastes like a fruit smoothie! I don't buy into much of anything without independent testing (not Joe Consumer's cheerleader letter) that verifies their claims.
I've gotten over 34mpg in my 1997 Civic with 190+k miles on it just by aiming to keep RPMs under 3k on my around town trips. Mind you, that 34mpg didn't include ANY actual highway driving - and have I mentioned it didn't cost me a penny in products?
Inform yourself:
AF User Guidelines
Old 02-09-2012, 09:34 PM
BrianAlex's Avatar
BrianAlex BrianAlex is offline
This kind of thread always gets me.
For one thing nobody is even considering the fact that all odometers are not exactly calibrated. Even if they were, the diameter of the tire changes as it's tread wears off.
So how can anybody have an intelligent discussion about accurate MPG when the "miles" is an unknown quantity in any car that doesn't have a special meter in tow? As I recall, most odometers are off by up to 5%.
Secondly, this is a sensationalistic article by Edmonds. If some of the tested cars were 19% off but the average was 5%, then it would have to be true that a certain number of cars were much closer to 0% off.
Dividing your "miles" driven by "gallons" purchased would only be accurate if your odo was spot on, the pump meter was 100% accurate,and unless you used many tanks to get the figure then the results would be skewed by ambient temperature differences, pump differences, angle of car on pavement at the pump, temperature of the gasoline (did they just get a shipment and the gas is 20 degrees warmer than the last time you filled?) etc.
So just put in the gas and drive in a manner as to keep the "mileage" gauge in it'a highest reading if it's important to you otherwise just drive and forget about it.
Also my heart bleeds about the articles mention of an SUV driver that thinks he is getting 12.5 MPG but actually gets less. Screw him. -BA
Old 02-11-2012, 04:08 PM
jamesslcx jamesslcx is offline
That's amazing that some people can get significantly better fuel mileage than the EPA listing. If everyone could do that we would have no need for hybrids or electric cars. I think a lot of it is how people drive and traffic conditions, and yes I can see how the Kiker wires can help in certain instances. In the end it's all about how you maintain a vehicle and how you drive, I have a neighbor with a Prious and he complains about his fuel mileage and after riding with him once I can now see why.
Old 02-12-2012, 12:14 AM
KalebC KalebC is offline
Even the difference of one or two MPGs can make a huge difference when thinking about what kind of car payments you can afford, especially for a heavy commuter. If we're talking a 19% difference on a $100/month fuel bill, that's a huge margin. That's like the difference between leather/audio upgrade or not--or, the car you want versus the car you can afford.
That's why it's important to look at independent reviews by organizations, like Edmunds, who have actually done the work to see what the true average fuel economy is.
And, that's why proper maintenance and driving habits can save you a bundle.
Observe, Hypothesize, Test, Respond.
Dream, Act, Reflect, Plan, Repeat.
Full Disclosure: I sell a fuel additive.
looking for a cheap awd/4wd suv that gets good gas mileage apache101786 Car Buying Q&A 3 02-18-2011 07:15 PM
Automakers get good mileage for money on test tracks - Arizona Republic Automotive News Automotive News Desk 0 05-06-2006 10:50 PM
cheap offroading truck. but also gets good gas mileage. mike5721947 Engineering/ Technical 8 12-01-2005 06:49 PM
Think you can afford a Skyline?? THINK AGAIN. Skyline69 General Discussion 31 10-07-2004 07:06 PM
If you're thinking about a RWP stage 3 turbo w/150+hp and 12 psi think again Kartoon 1 Lancer 1 12-03-2002 03:20 PM
Tags
economy , efficiency , fuel , mileage , mpg
