turn signal stays on.
Hello everybody,
I have a 2006 durango limited. I do not know if this has anything to do with my problem, But I hooked up a trailer and blew a fuse. Replaced the trailer wiring harness fuse. I then had all lights on the trailer and vehicle. But the right turn signal would not work. (flashed fast) I then un hooked the trailer and still had the same problem. Then once I turned off the Durango The right turn signal remained lit. ALL POWER OFF ! still lit up solid. I then replaced the brake light bulb and turn signal. Still will not turn off. Any suggestions would be greatly appreciated.
