Old 11-12-2003, 10:57 AM
ianhzl ianhzl is offline
Question TUrn Signal Stays On, bulbs working
I have a 95 Pontiac Grand Am and when I turn on the right turn signal it just stays on, no blinking. All the bulbs are on, none are out. The left signal works fine. However, when I use the hazard lights, all th elights blink except the right front one. That does nothing. Also the right signal light on the dashboard display does nothing with the hazards on, but stays on (no blinking) when the right blinnker is on. The left signal on the dashboard display works fine. Does anyone know what might be wrong and where in the car the faulty part is?
Old 11-12-2003, 09:30 PM
99gasc/t 99gasc/t is offline
Re: TUrn Signal Stays On, bulbs working
u have a bulb out. there is more than one bulb in the front. make sure all of them are good. if they are then u got a relay problem. look in your owner manual and look in the fuses and relays and it will tell u where the relay is at
Old 11-12-2003, 10:17 PM
Smile
Thanks, you were right! There is a second bulb in the front and it is out. I didn't notice the one in the bumper. Thanks again.
Turn Signal Stays On!!! Help!!!!!! seajsd Eclipse Problem Diagnosis 9 04-06-2006 04:52 PM
2000 Mitsubishi Eclipse-turn Signal Stays On! seajsd Eclipse Problem Diagnosis 2 04-05-2006 10:25 PM
Turn signals stay on and don't flash. Onimacus Corsica 1 08-17-2005 08:11 PM
turn signal staying on and not blinking wehswarriorS-10 S-10 5 11-02-2004 04:11 PM
97 s10 turn signals stay on jaymst S-10 1 06-05-2004 06:30 PM
