Old 06-04-2011, 07:45 PM
jcurry05 jcurry05 is offline
AC fan only working on highest setting
Hey everybody, the fan for the air conditioning in my 2000 GP is only working when it is set on full blast. Does anybody know why its doing this and how to fix it? thanks
Old 06-04-2011, 08:21 PM
duke_winchester duke_winchester is offline
Re: AC fan only working on highest setting
It sounds like the relay has gone bad. I believe it is underneath the passenger side dash board. I think u can access it from underneath.
Old 06-04-2011, 08:28 PM
brcidd's Avatar
brcidd brcidd is offline
Replace your blower motor resistor - the high speed relay is part of that module- follow purple wire backwards from blower motor to find the module.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-04-2011, 08:39 PM
Sorry, that is the part I was looking to say - the blower resistor. Thanks
Old 06-05-2011, 10:01 AM
Thanks guys. Sounds like that may be the problem. I'm going t check it out today.
Old 06-07-2011, 03:57 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
just a tip, if it is the blower resistor (which I agree is the problem) the back two screws that hold it in only need to be loosened (not totally removed). They are hard to reach and this will make replacement much easier. Also, removing the blower motor (it's held in by only 3 screws) will make access to the resistor much simpler.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 06-07-2011, 09:56 PM
brcidd's Avatar
a 2000 GP is highly susceptible to the famous water deflector coming loose. Water can ruin the blower resistor and blower motor- from air intake that the deflector has dropped off-- check under air inlet cowl for rubber deflector to be unglued and fallen down on top of blower motor air inlet.
Do you ever see water on passenger floor after a rain?
'99 GMC Yukon
1998 Pontiac Trans Sport radiator fans only work when the AC is turned on amikayla Montana/Montana SV6 1 06-01-2010 12:25 PM
01 Impala fan only works on #5 setting, 1 thru 4 don't work... kjlj Impala | Impala SS 2 11-28-2005 07:19 PM
AC / fan only works on higher settings threegoofs Windstar 9 08-14-2005 01:26 PM
My fan switch only works on setting 4 but not on 1,2 and 3. What's wrong with it? rokhill Maintenance 3 10-23-2003 02:06 PM
My fan switch only works on setting 4 but not on 1,2 and 3. What's wrong with it? rokhill Cavalier 3 07-27-2003 05:07 PM
