Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 07-26-2003, 01:17 PM
rokhill rokhill is offline
My fan switch only works on setting 4 but not on 1,2 and 3. What's wrong with it?
Hi
I own a 1996 chev cavalier. When I turn on the fan switch, it only works on setting 4 but not on 1,2 and 3. What wrong with it? Can I fix this myself? Is it expensive?
Old 08-12-2003, 09:31 AM
bilbo33 bilbo33 is offline
sounds like your fan motor resistor pack dont know where it is located on your vehicle not familar with that type,check with your manual,had a similar problem on my primera managed to resolder breaks on circuit board,yours might be a similar type,hope this helps
Old 10-01-2003, 10:03 PM
CHEN119 CHEN119 is offline
Re: My fan switch only works on setting 4 but not on 1,2 and 3. What's wrong with it?
My 96 G20 has same issue, fixed with the following solution, Good Luck!
The climate control system has 4 speed settings. The 4th setting allows the blower to run at the motor's full speed. However, for the first 3 settings a resistor is needed to get the proper motor speed. The resistor effectively reduces the current fed to the motor making it run at slower speeds.
The blower motor resistor tends to have a high failure rate. When the resistor goes bad the fan will only operate on the 4th setting. This is a fairly common problem with an inexpensive, easy fix. The resistor can be purchased from a Nissan dealer at a retail price of $24.83 (there are sources of OEM parts at prices below retail). The part number is 27150-2M105.
To replace the resistor look behind the glove box next to the blower fan. Two phillips screws will need to be removed and the old resistor can be removed and the new one plugged in. This repair doesn't require removing any other parts from the car to access the resistor.
Old 10-23-2003, 02:06 PM
trinispeedd trinispeedd is offline
yep it is your blower resistor motor use this link to see how to fix it
http://www.cardomain.com/memberpage/299921/2
good luck
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
