Old 05-08-2011, 10:49 AM
S10SNODOG's Avatar
S10SNODOG S10SNODOG is offline
HOW THE HELL do you get the YOKE FLANGE OFF DIFF
OK 2003 chevy S-10 pick up i cant for the life of me get the YOKE out of the DIFF I tried banging HARMONIC PULLER,STEERINGWHEEL PULLER, all kinds off stuff and they wont fit I read about a pininon flange puller J-8614-1 but $ 325.00 I dont think so and no one has it anyway any help please Anthony
http://i293.photobucket.com/albums/m...-51-07_217.jpg
http://i293.photobucket.com/albums/m...10-51-22_8.jpg
Old 05-08-2011, 01:30 PM
maxwedge maxwedge is offline
A990 racer
Re: HOW THE HELL do you get the YOKE FLANGE OFF DIFF
If you cannot get a large enough puller from any source maybe rent or borrow one, try using 2 fairly heavy brass hammers and using 2 people try to hit the yoke from both sides at the same time, doing this you may damage the rear pinion bearing though.
The Following User Says Thank You to maxwedge For This Useful Post:
S10SNODOG (05-08-2011)
Old 05-08-2011, 01:43 PM
jdl jdl is offline
Did you try penetrating oil on it, put some good tension on it. Walk off and leave it for about 30 minutes or an hour. Come back and try some more tension on it.
If your going to replace everything anyway, use a little heat on the yoke. Be aware, if any hot oil or grease blows out on you, it's going to leave a mark. Use safety glasses. If your not comfortable using heat, then don't. Safety is your responsibility. I wouldn't want pressure to build in the diff.
The Following User Says Thank You to jdl For This Useful Post:
Old 05-08-2011, 03:54 PM
S10SNODOG's Avatar
I got i off with a bearing puller I noticed an xtra seal on the yolk itself that doesn't have to be replaced does it I'm only replacing the seal that punches into the diff housing
Old 05-08-2011, 05:55 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
They usuall do not leak out the yoke splines but.
A little silcone sealer on inside of yoke splines beforem installing it will seal the splines.
MT
The Following User Says Thank You to MT-2500 For This Useful Post:
Old 05-27-2011, 06:54 AM
rprough's Avatar
rprough rprough is offline
Ya had a heck of a time getting it off so might as well replace other seal while its off.
God Bless America
Old 05-27-2011, 07:16 AM
S10SNODOG's Avatar
I use a ball joint puller The big 1 They had two claws on it it worked well the other seal you speak of is on the yolk and I believe it's a dust seal I got it together no leak but I do have a small vibration not sure if it's bearings
in the rear housing
Old 06-20-2011, 07:02 AM
rprough's Avatar
Did you match mark the yoke to the housing and u-joint before you took them off so they could be put back in the same position? Very important. This is my guess what small vibration is from.
God Bless America
Changing Sparkplugs. How the hell do you get the one behind the steering shaft out? XtremeXP Jimmy 5 02-04-2004 05:56 AM
Frustrated----> How do you get the shifter off????? NiSmO_zt 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 14 09-04-2003 05:21 PM
How do you get the cat off a 90 GS? Bolted SO TIGHT!! 90gs Integra 7 04-21-2003 12:11 PM
Need Help, replacing tweeters, how do you get the door panel off? tgunnerson Integra 2 07-22-2002 01:02 PM
