Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-18-2002, 01:05 PM
tgunnerson tgunnerson is offline
Need Help, replacing tweeters, how do you get the door panel off?
Hey guys and gals, I've got a 94 Integra GSR and have some new Kicker 6.2s. I can't figure out how to get the darn door panels off. I think I got everything but the door handle housing. Anyone have any hints?
Thanks in advance.
Todd
Old 07-22-2002, 12:09 PM
pyter400 pyter400 is offline
Send a message via AIM to pyter400
is 94 3rd gen if not then it should just have clips you kinda have to force it it feels like its gonna break but then the face just pops off
Old 07-22-2002, 01:02 PM
97teg 97teg is offline
I've taken my door panel off at least 10 times now replacing speakers and wiring and stuff. Heres what you need to unscrew:
1. The door handle for opening the door has a small flap that you have to pry open with a small screwdriver. Unscrew the screw behind the flap and remove the whole plastic piece by pulling the handle that opens the door and slipping the plastic piece off.
2. The handle on the armrest has a screw at the bottom of it, unscrew that and remove the plastic handle.
3. There is a plastic screw near the front top of the door, it is covered by the dash when the door is shut. Unscrew that about halfway then pull the whole piece off.(it has 2 pieces, you can get it off easier if you pull it out with the screw)
4. Then starting from the bottom side of the door, slip your fingers between the panel and door and start pulling. There are plastic tabs that hold it on the door, just pull them off one by one. don't worry, it will make popping noises as you pull the tabs out but its not breaking it.
5. After the panel is free you have to pull the panel straight up because it hangs on the window slit.
Hope this helps.
how to change the window regulator and get the door panel off jerry1967 Regal 2 02-04-2009 10:03 AM
How to get my door panel off Ofnarcr Eighty Eight 3 05-10-2006 01:53 PM
how do I get the door panel off to replace mirror? kkwelcher ZX2 3 01-11-2006 10:55 PM
Getting the door panel off Diceman83 Car Audio 6 04-10-2005 07:50 PM
How do you take the door panels off a 2001 Blazer? chicago_guy Blazer 2 12-30-2003 03:05 PM
