Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-19-2003, 03:36 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
How do you get the cat off a 90 GS? Bolted SO TIGHT!!
I was going to take off the cat and put a straight pipe in its place because i want that extra power so i looked under the car and saw that it was bolt-on and im like oo easy so i break out the socket wrench kit and pull on it with all my might and it wont even budge, and im a big guy! is there any junk you can spray on it to make rust or oxidation or whatever is locking it in place go away??
Old 04-19-2003, 04:16 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Lube and breaker bar. When you get the pipe in spray anti-sieze lube.
Old 04-19-2003, 04:22 PM
90gs's Avatar
lube like wd-40 or what? and whats a breaker bar
Old 04-19-2003, 08:03 PM
IntegraB18LS's Avatar
IntegraB18LS IntegraB18LS is offline
WD-40 should work. breaker bar is a bar that you attach to your socket to give you a long reach, there for more power. If you have lifetime warntee tools just put a pipe on your wrachet. If you have access to air tools get a impact gun and use that, should have no problem.
Kyle
Old 04-20-2003, 06:48 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
i used wd-40 and then i put the pipe from the jack around the wrench and hit that shit a couple times. Try it with a hammer if u need too. It is pneumatically tightened so don't think u are too weak....
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 04-20-2003, 09:14 PM
90gs's Avatar
i weigh 220 and i bench 265 so i wasnt thinkink i was weak.. i thought that it was just weathered on there or something... my friend said he had his car up on a lift and hung on the wrench and finally the bolt snapped
Old 04-20-2003, 09:17 PM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
get a grinder and just grind that bitch off
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 04-21-2003, 12:11 PM
90gs's Avatar
i was going to just hollow that crap out because i have no money right now and cant afford a test pipe (i know how cheap they are too)... what kind of junk is in a cat, its it really messy?
