Old 03-19-2011, 09:53 AM
Loungerist Loungerist is offline
Died
Hello,
Yesterday I started up my 2000 Grand Prix and drove home. I went inside real quick to grab something but when I came out and tried to start the car absolutely nothing happened. There was no electrical response at all. The battery showed no sign of being weak and I tightened the battery cables just to be sure there was no disconnection. I didn't have time to try to figure out what was wrong yesterday but it's still dead this morning. What other than the battery can cause a total shutdown like this?
Old 03-19-2011, 10:00 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Died
The battery is a good starting point. If you have an Autozone nearby get it tested for free. Also, you can measure the voltage with a multimeter. Just go across the battery positive and negative terminals. Normally you should see around 12.5 volts on a properly charged or good battery. This is with ignition to OFF.
Timeslip 08/12/06
AF Community Guidelines
Old 03-19-2011, 10:27 AM
Re: Died
Thanks. I plan to get the battery tested/charged later today once I can get a ride. But just in case it's not the battery, what else could it be? Because I hope it's something as simple as the battery, but with the bad luck I've been having this week I have a feeling it's not.
Old 03-19-2011, 10:31 AM
BNaylor's Avatar
Re: Died
Other than the battery cables and terminals possibly the alternator. But AZ will test the whole charging system too.
Timeslip 08/12/06
89 Chevy S-10 with a 2.5L turns over but dies Aitcheson Problem Diagnosis 6 09-13-2010 07:03 AM
Die, parking warden, die crayzayjay Stress Release 33 10-27-2004 03:19 AM
Memphis Italian Auto Show ***56k Die--T1 Maybe Die*** Sid 6.7 288 GTO | F40 | F50 | Enzo 7 07-28-2004 02:50 PM
Die Honda Civic,DIE PinkyJones Car Modeling 39 04-07-2003 11:55 AM
Die Supercarsite.net Die! NissanZ@af Stress Release 20 03-03-2001 05:28 PM
