Old 03-14-2011, 11:59 AM
Techniker Techniker is offline
O2 Sensor Cleaning
This is more of an academic question than anything. I know it's almost just as cheap to get an aftermarket sensor, I'm just more interested in the responses here. I am replacing an O2 sensor on a car (not my own this time) and have managed to pull an old OEM sensor off at a junkyard. When I think about the years of exhaust gases blowing past it and, before I go through the trouble of installing it, I would like to try to clean it up a bit.
Any suggestions about how I could do so without pulling off platinum catalyst along with it?
If you really must know why I would want to do this- it's more of a project for me than anything else- I prefer to try to fix something before I get a whole new one. I also rebuild alternators (and even starters) when economically it would be more viable to just replace them.
Thanks,
Techniker
Old 03-14-2011, 12:26 PM
danielsatur danielsatur is offline
Re: O2 Sensor Cleaning
I would think you could use a propane torch to clean plugs & H20 sensors.
Don't forget to use Anti seize compound.
Caution -
Remove plugs when Aluminum heads are cold.
H20 sensors canbe hot, but be careful.
Cleaning O2 Sensors CCMphysician Engineering/ Technical 4 01-15-2010 07:47 AM
01 Silverado ABS Sensor Cleaning JFLS40 Silverado 10 06-29-2005 07:44 PM
New range sensor clean up write up +98: amigo-2k Rodeo | Passport | MU 1 04-16-2005 08:00 PM
CO2 Sensor cleaning SebringYves Windstar 3 02-20-2005 08:27 AM
MAF Sensor, Clean vs replace mlittlestone Ninety Eight 4 12-12-2004 09:52 PM
