Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 07-21-2004, 11:26 AM
mlittlestone mlittlestone is offline
Question MAF Sensor, Clean vs replace
I have recently changed my ECM and the Check Engine light still comes on sometimes. Prior to changing the ECM I had a shop analyze my engine and it noted I need a new ECM and MAF sensor.
Should I try to clean the MAF sensor or should I just replace it? If I try cleaning it, what should I use?
God Bless
Old 08-22-2004, 12:33 AM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
Re: MAF Sensor, Clean vs replace
Replace it. You can't clean it without damaging it.
Old 10-02-2004, 11:02 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Spit, replace it. If you try to clean it, you'll more than likely damage the element and need a new one anyway. Cleaning them rarely ever works anyway.
Old 12-11-2004, 02:14 PM
Blane1956 Blane1956 is offline
Lightbulb MAF Sensor
I agree that cleaning the MAF can can result in damage. But if your going to replace it anyway here is a little trick you can try: MAF's, MASS's, IAC's, and throttle plates can be cleaned with Brake Spray Cleaner. It's worked for me. Good Luck!!
Old 12-12-2004, 09:52 PM
have98 have98 is offline
I replaced my MAF with one I got from an auto wrecker. It is still working well after 2 years and I saved a lot compared to purchasing new. Easy to replace as well. I think 3 screws and a connector.
