Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-16-2005, 07:23 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Cool New range sensor clean up write up +98:
Someone emailed me this to include in the FAQ's.
http://isuzufaq.ibctech.ca/range.pdf
1.2 megs (nice high res photos).
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 04-16-2005, 08:00 PM
johnsm johnsm is offline
The only things I would add is to spray the main nut holding the range sensor on with penetrating oil the night before you attemp to remove. Then I would disconnect the shift linkage (by prying off with a flat screwdriver). After four years my nut was seized up and I damaged the shift cable.
Secondly, I would thoroughly clean out the torx screw heads. They will be loaded with dirt and rust. If you don't you may strip the head and be stuck finding an alternative method of removing (and replacing) the screw.
John
