2000 Silverado ABS Sensor Cleaning
Has anyone done this and can either tell me what steps to take to access the front sensors or even email me digital pics of it?
Do I need to pull the wheel, rotor, dust cap, outer bearings just to get to the abs sensor to clean it? Any help is much appreciated... Jeff [email protected] |
Re: 01 Silverado ABS Sensor Cleaning
Correction: 2000 Chevy Silverado 2wd.
39 viewers
39 people viewed this post and not one bothered to reply??
Never done it but the Haynes manuel has great pics of that nad other things you will probably work on in the near future. I suggest you get the Haynes on you... J/K
I've also been meaning to pick up a copy of the Haynes manual...
![]() ![]() ![]() "When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson 2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster |
Is that the Haynes or Haynes her Way???????? J/K Come on laugh .....LOL
Re: Re: 01 Silverado ABS Sensor Cleaning
Did GWB really give the finger or did someone doctor that up in picture editing software?
I did it on my 2000 Sierra, the brake calipers & rotors have to come off. you might have to beat the rotors off, so be prepared to replace them if you cant get them off easy. Once you have the rotors off you will see the sensor in the hub. Take the bolt off & remove the sensor, then clean off the sensor and file down the mounting surface on the hub to remove the rust that has built up. When reinstalling the sensor, put a thin coating of RTV sealant on the mounting surface to keep water from entering. I am assuming this is to fix the low speed ABS activation problem that GM should be recalling soon.
Sorry, but my reply was for a 4wd truck
call gm
if anyone else is having abs activation around 6mph for no reason please call gm so we can get this hazard fixed. 1-800-222-1020
Re: Re: Re: 01 Silverado ABS Sensor Cleaning
