Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 02-27-2011, 12:27 PM
itsjake21 itsjake21 is offline
Question 2001 4.0 ranger burning smell
Hey last night I took my new ranger for a drive, I noticed as I got on the freeway on ramp and accelerated there was a burning or hot smell coming from my heater. It stopped after a couple of minutes of freeway driving. Then when I got home I tok it in the fields behind my house and ended up having to use the 4x4, when I got home and got out I noticed a burning smell near the front drivers side tire I popped the hood and looked around and couldn't figure out where it was coming from. Has anyone else had this happen, or know what the problem could be?
Old 02-27-2011, 02:13 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: 2001 4.0 ranger burning smell
Welcome to the Automotive Forums!
Any chance you have a dragging caliper?
Feel each wheel and it should be warm, if it's hot to the touch you've found a dragging brake.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 02-28-2011, 07:11 PM
thanks for the tip but that wasn't the case, any other ideas? Also I have a airbag like in my dash that flashes on and off intermittently
Old 02-28-2011, 08:12 PM
olopezm's Avatar
There is a recall for many ford vehicles on the Brake Pressure Switch, did you get it done already? If not, then I would inspect it immediately as fluid leaking into the switch can cause a short circuit and start a fire. It is located ver close to the brake fluid reservoir. you can google it so you know how it looks like.
The airbag light can be many things from a bad clockspring, bad crash sensor or a bad wiring, also a short in the electrical system can cause lots of electrical gremlins, did the light started at the same time as the burning smell?
If it is equipped with a cruise control system, is it working? If not then you have a bad switch.
Here's a link with information about it:
http://www.switchfires.com/
Best regards,
Oscar.
Old 02-28-2011, 08:41 PM
olopezm's Avatar
By the way, is the airbag flashing in an apparent pattern? for example:
ON,OFF,ON,OFF,ON,OFF - PAUSE - ON,OFF,ONOFF - PAUSE - STAYS ON
If so count the number of flashes before and after pause in the example above it indicates 3 flashes, pause two flashes indicating DTC 32 (just an example)
Old 03-09-2011, 09:59 PM
lectraplayer lectraplayer is offline
My other truck (2002 Ranger XLT with 4x4 and 4.0) would occasionally have a slight burning funk like you're talking about. I liked that truck, but ended up in a freak wreck, which was all me. Never found what was hot though
1999 4.0 GC larado Cam and crank positioning sensor szellers73 Grand Cherokee | Grand Cherokee SRT8 4 01-19-2010 10:30 AM
2000 grand am 4 cyl - Oil burning smell inside car jayjp200 Grand AM 1 12-13-2009 10:43 AM
93 Yj 4.0 starts with high idle... IntenzInc Wrangler 0 04-04-2009 12:06 PM
04 4-Runner and Burning smell frank69m 4Runner/GX470 35 11-23-2004 10:29 PM
'93 4.0 ranger lacking power resliss Ranger | Courier 1 01-02-2004 04:42 PM
Tags
4x4 , burning , heater , ranger , smell
