Old 02-20-2011, 06:20 PM
kernsm kernsm is offline
1999 Silverado Drivers seat track
The manual seat track on my 1999 Silverado is broken and the seat will no longer lock in position. I would like to know if I can replace the manual seat assembly with a power seat assembly? If so, what years will work and is there a lot of wiring that is required?
Thanks,
Mike
Old 02-20-2011, 08:09 PM
slo99sierra slo99sierra is offline
Re: 1999 Silverado Drivers seat track
Thanks,
Mike
Junkyards or eBay would be your best bet. Look for seats out of 99-02 trucks. Though, seats from 03-06 could work also. I had done the conversion myself with some seats out of an 01 from a junkyard and I love it.
For 99-02's some components were plug-and-play, but on seats I'm not sure. I wired up my seat to an ignition power source at the column, and grounded it at a front mounting spot for the seat.
When you get your seats, make sure you get the wiring harness at the seat, the whole thing, you'll need it.
1999 GMC Sierra RCSB 4.3L V6 overall stock plus some exterior and interior work.
Old 04-24-2011, 11:47 AM
FrankB43015 FrankB43015 is offline
What wiring harness are you talking about? My truck only has a small connector under the seat. The electric seats I picked up (couldn't find a manual seat) has the small connector the a wider multi-pin connector.
Old 04-24-2011, 02:21 PM
The small connector would be your seatbelt sensor (you could leave it unplugged as it does not affect your air bag system like most newer model vehicles)
The other connector is the harness I'm talking about...it's the harness for your Power Slide, Power tilt and raise/lower. Does your power seats have power recline or manual recline?
Old 04-24-2011, 07:44 PM
I ended up swapping out the broken back. It's not show ready, but it works. Thanks anyway.
99 silverado-bad driver seat track darrellbrundage66 Silverado 5 05-16-2009 12:50 PM
Drivers Seat iamlocals How-To's and Walk-Through's 0 02-23-2009 12:29 PM
2006 Silverado Driver Seat rcm01 Silverado 7 02-08-2006 08:51 AM
Drivers Seat Track Issue dkaplan Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 3 11-01-2005 03:22 PM
1999 Denali Drivers Seat Heater Not Working Bretters21 Yukon 5 01-15-2005 05:37 PM
