Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 02-15-2011, 03:07 PM
Mizzm2 Mizzm2 is offline
Engine wont shut off
I have a 1996 Ford Explorer. The engine keeps running after I turn the car off. I replaced the ignition key switch and its still doing the same thing. What else could be the problem?
Old 02-15-2011, 03:30 PM
danielsatur danielsatur is offline
Re: Engine wont shut off
How about a stuck on Relay!
Old 02-16-2011, 01:51 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
The problem is likely the ignition switch rather than the key cylinder. The ignition switch should remove power from the "Run" circuits when the key is turned off. Any chance someone spilled soda or sugary coffee in the steering column? You might be able to just spray some contact cleaner in to the ignition switch and get another year or two out of it.
-Rod
head swapped. now my alarm wont shut off. anyone know how to shut off alarm? bratt Mustang Problem Diagnosis 1 05-02-2010 05:26 PM
Radio wont shut off when car shuts off and door opens 95aurora83 Aurora 2 02-26-2009 07:22 PM
radio wont shut off when car shuts off and door opens newscarver Aurora 2 02-07-2008 06:08 PM
98 blazer heat wont shut off a/c wont work compressor working kellycoplen Blazer 0 07-14-2004 03:24 PM
'96 Grand Cherokee....Engine wont shut off huf67 Grand Cherokee | Grand Cherokee SRT8 0 01-03-2004 10:57 AM
