Old 12-05-2010, 10:35 PM
molczak714 molczak714 is offline
1994 AWD Front leak w/pictures
Hey guys i have a 1994 astro ext van awd cambridge edition. It has 275,xxx miles on it and still runs strong. Couple days ago i noticed a leak, well a drip, and not constant. Looks like it was driping from the front diff on the drivers side now take in mind it does not grind, pull, make any type of noises. Which makes me think that there is nothing broken i have taken a picture so you guys can see what is going on here. Some people say that the axle poped out but if the axle poped out wouldnt it affect the right wheel in any way. Im just confused and need some help i love the astro i bought because it was awd snow came and i cant use it any advice would be good thanks. Dont mind the date on the picture it was take couple days ago. Oh yeah and i forgot to mention like i said its a awd the front tires are 215/75/r15 and the back tires are 235/75/r15 would that have anything to do with it.
Old 12-06-2010, 06:41 PM
old_master's Avatar
Advisor/Moderator
Re: 1994 AWD Front leak w/pictures
It appears to be the output shaft seal. Front axle shaft must be removed to replace the seal. With AWD & 4WD, all 4 tires must be the same size, (best if they're the same manufacturer), and tire pressure must be equal in all 4 tires. Difference in tire size probably didn't cause the leak, but it will cause other problems.
You have to know how it works,
to figure out why it doesn't.
Old 12-06-2010, 08:12 PM
Blue Bowtie's Avatar
Registered Offender
From the photo, it appears that the CV may not be fully seated into the differential housing. If you can easily move the body of the CV in and out, it isn't locked into the retaining groove provided in the stub shaft. That may indicate other problems.
As the Master indicated, running different size tires will quickly destroy the transfer case. You'd be lucky if it hasn't done so already.
Old 12-07-2010, 01:20 AM
Not much difference in width tho. 215 vs 235 i dont think that would cause any problems. I looked down below and tried to move things around and everything is in place nothing moves or anything like that im so confused some people say it popped out but when i did research for a popped out axle there are a few things that just dont have anything to do with my van. Just a few drips no clings nothing popping or wobbling nothing like that.
Old 12-07-2010, 08:30 AM
Dobaroy Dobaroy is offline
It would be best for the AWD to be on the same size tires all the way around.
Old 12-07-2010, 05:15 PM
old_master's Avatar
Advisor/Moderator
Originally Posted by molczak714 View Post
...Not much difference in width tho. 215 vs 235 i dont think that would cause any problems...
Width is not the problem, circumference is where the problem is. The 215's turn 728 revolutions per mile, and the 235's turn 698 revolutions per mile, and that's a substantial problem when it comes to AWD, 4WD, ABS, and the speedometer. The difference in RPM WILL cause a problem. As Blue Bowtie mentioned, you'd be lucky if it hasn't destroyed the transfer case yet.
Old 12-10-2010, 09:58 PM
Took a look at everything transfer case is fine what caused the problem is the c clips broke and caused the axle to slide out probably made the seal go bad, replacing the c clip and seal tomorrow brrr its gonna be a cold one 6-8 inches of snow plus another 2-4 at night gonna be a fun one.
94 Astro AWD - front brakes? stan_5150 M Bodies 2 04-06-2010 08:47 PM
97 Dodge ram 1500 4x4 Front axlel leak drugaria Ram Pickup | Ram SRT10 2 11-12-2009 06:17 PM
2002 town country awd - front end noise ALUVSR Caravan | Voyager 2 05-06-2006 06:51 PM
1991 astro AWD front driveshaft interchanges? ron1991 M Bodies 1 03-26-2005 09:47 AM
95 AWD front brakes pulling right Cadilad M Bodies 6 12-30-2004 04:57 AM
