Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-12-2009, 11:18 PM
drugaria drugaria is offline
97 Dodge ram 1500 4x4 Front axlel leak
Ok, recently I had to replace the left side(driver's side) u joint on the front axle. I did everything myself and took great care not to damage the axle seal. But with my bad luck the seal started leaking couple months after the repair. I also have a tiny leak at the vacum switch (square box on axle , passenger side) .That small leak is really no problem, but would like to fix it if it's not a big deal. As far as the left axle shaft seal leak, it seems to be getting worse and I have to fix it. So my question is what special tools do I need and what is the procedure to fix it? Taking it to a proffesional mechanic is not an option due to my financial situation.
Old 11-12-2009, 01:52 AM
Re: 97 Dodge ram 1500 4x4 Front axlel leak
This forum really sucks, not a single reply for over a month
Old 11-12-2009, 05:17 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Here's something,
http://www.automotiveforums.com/vbul...ront+axle+leak
Here's something about the seal,
http://dieselpowerman.tripod.com/Fro...xle%20Tech.htm
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Tags
axle , front , leak , seal , shaft
