Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 11-22-2010, 05:34 PM
rs6er rs6er is offline
Driver's door window doesn't work
Activation the switch does nothing. Is this a switch issue?
2001 Suburban 1500
Old 11-22-2010, 05:36 PM
shaallkie shaallkie is offline
Re: Driver's door window doesn't work
is the passenger window working
Old 11-22-2010, 05:37 PM
Yes
Old 11-22-2010, 05:41 PM
Most likely the switch. I would use an ohm meter to test the switch
Old 11-22-2010, 07:04 PM
j cAT j cAT is offline
2001 Suburban 1500
these door window units are a common failure item ...I have replaced a few...
open the door panel and using a meter check for voltage at the door motor connector..with the switch depressed..
check the steel cables for damage...
then give the window motor a good hit when depressing the switch ..if it begins to work you will need a new window regulator unit..
1AAUTO has these ..I got 2 for 130.oo ..better than OEM and much cheaper..
Old 11-24-2010, 08:24 AM
The switch clicks when I push it, so I think it may be working. Can anyone point me to directions on how to get the door panel trim off?
Old 11-24-2010, 12:23 PM
lift up on the switch panel plastic pops off. remove the other plastic parts around the handle . also the triangle piece near the door mirror, then unscrew the screws .. lift the door panel up to remove..easier with the window down..
pull panel away from the door frame slightly to find any screws still holding...
Old 11-27-2010, 10:08 AM
I got the switch unit out of the truck, but I'm having difficulty removing the back. Even with the tabs removed from their holes, I can't pull it apart. Someone suggested I swap switches with the passenger door, but this things just got a circuit board on it. How can I test that switch, or is there something else I should be looking at?
I guess the only way to check if the window mechanism works is to jump the terminals in the connector. Does anyone know the colors of the wires coming from the driver's door window motor? A new switch is over $100.
Old 11-27-2010, 06:44 PM
WHAT IS THE VOLTAGE AT THE WINDOW MOTOR?????? this is the next step...when the switch is depressed..................
Old 11-27-2010, 07:28 PM
Pulled the plug on the window motor and inserted the probes into the connector. With the switch operated I am getting 12V. There is some corrosion on the motor. Does this mean I have to replace the motor? Everything else looks good. If the motor is the problem, could I replace it with one from one of the rear doors? The passenger door?
Old 11-28-2010, 01:05 PM
ok now your getting down to the open the wallet, as the next step.
1A AUTO has these . this is where I get my window door regulators as they call them..this is how it is repaired.. not too hard to do..
with the window held in the up position firmly, with duct tape etc remove the assy ..then install the new one..
this takes 1hr max...then after you do this one, the passengerside one will only take 30-45min.......
use white lithium grease on all the cables and slides..spray the rubber track with silicone ...............
Old 11-28-2010, 01:30 PM
OK.
1. Why can't I just buy the motor without the whole regulator? I can get that from Rockauto.com for only about $25. The rest of the mechanism looks fine.
2. Why do I need to do the passenger side too? It's working fine.
BTW, thank's for all your help with this.
Old 11-28-2010, 05:59 PM
OK.
I never could replace the motor on my vehicles repaired. perhaps you can. also the motor failure is one possibility the other is the cables breaking.
driver window goes first normaly then soon after the passenger side. thats why I said when you do the passengerside It will take less time.
this should have been a recall..
Old 01-01-2011, 10:23 AM
I have the new regulator & motor from 1AAuto in. One question: do I leave the zip tie connecting the 2 cables (forming an X) on?
Old 01-01-2011, 05:42 PM
yes that should be there to keep them secure , grease the steel cables... spray the rubber guides with silicone spray..
2001 Venture Driver's Door Window phipps Venture 6 03-08-2008 11:21 PM
Master Window Switch: Driver Window Doesn't Work loca247 Jimmy 0 08-28-2007 08:52 PM
03 Envoy - Driver's door window controls don't work!! amageed Envoy 2 07-25-2007 02:14 PM
Driver's side window not working doublecurious Windstar 12 10-07-2006 10:06 AM
driver's rear side window doesn't work dmorlow Aurora 7 07-09-2004 09:10 PM
