Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 07-25-2007, 06:48 AM
amageed amageed is offline
Unhappy 03 Envoy - Driver's door window controls don't work!!
Hi all! I have a new issue that arose yesterday and need some help. For some reason, the 4 window switches located on the driver's door do not work anymore, however, the power locks and window lock buttons both still work. All other window control switches work fine on all the other doors though. I checked the fuses and did not appear to be any blown (at least from what I could see). I did not see a specific fuse for power windows but I did switch the Driver's Door Control fuse with the Passenger Control fuse and no change. Any ideas???????
Dan
Old 07-25-2007, 01:46 PM
fortcarp fortcarp is offline
Re: 03 Envoy - Driver's door window controls don't work!!
Sounds like master control module in driver's door. If it turns out it is for sure, a pretty easy fix. Look on gmpartsdirect.com or rockauto.
Carp
'03 TB LT EXT, Black
Old 07-25-2007, 02:14 PM
Thanks for the reply. It would make sense that it is the master control module as I checked and it does have power running to it but not working. I will make the investment and replace the module and see what happens.
