Old 10-14-2010, 08:09 PM
rteas48183 rteas48183 is offline
2002 Taurus 3.0 OHV Little to NO HEAT with a Newborn baby
Ok i got a 2002 Taurus with the 3.0 OHV heat and A/C were working fine 2 weeks ago, with no temperature problems at all. Well last weekend we had a cold snap. I started the car up 20 minutes before we left out, got to where we were going and realized that the heat was very weak temp, and the temp gauge on the car was barely off of cold. So i cut the heat off, then the guage went to buried cold. So i got the thermostat and fluid changed by the "pros" which did help with the cars temperature, but my heat inside is still a very weak temperature. What else could be the issue??? i was hoping the t-stat was stuck open, which seems to have been part of the problem, but i need to have this thing fixed 100% Please any help at all will be greatly appreciated. Does anyone know where to buy those little 12V Plug in Heaters???? j/k
Old 10-14-2010, 10:12 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2002 Taurus 3.0 OHV Little to NO HEAT with a Newborn baby
The heater cores are known to get restricted with junk in several years of Taurus. You can backflow the heater core which will probably get you good heat for this winter. There is also a ground strap kit that you can install to reduce the chance of future corrosion/restrictions.
-Rod
Old 10-24-2010, 10:36 AM
bigbadtrucker bigbadtrucker is offline
taurus has a bad problem of the heater core getting clogged with rust and debris, you can flush the core but the question you should ask is where did the stuff come from. most likely the water pump, at 100,000 miles or so the fins on the water pump rust off and reduce circulation of coolamt and the rust and debris clogs the heater core. i have worked on alot of these cars and that is usually the problem. so if you change your heater core you should also put a water pump in because it will save you alot off headache and more than likely your engine for just alittle more work
2002 Taurus 3.0 oil pressuure elca69 Taurus | Taurus Wagon 3 12-29-2009 02:34 PM
2000 3.0 24v hard to start wagon. Tglass Taurus | Taurus Wagon 4 07-07-2009 03:26 PM
93 Taurus 3.0 Wagon need help with part! bgates612 Taurus | Taurus Wagon 2 02-18-2007 03:34 PM
2002 Taurus 3.0 rear engine oil leak 36K heavy2500 Taurus | Taurus Wagon 0 01-14-2006 11:06 AM
2002 Taurus 3.0 stalling sonicblue2003 Taurus | Taurus Wagon 0 08-29-2005 10:01 AM
