Go Back   Automotive Forums Car Chat > Buick > Regal
Old 07-17-2010, 04:07 PM
jerry1967 jerry1967 is offline
Steering Wheel shakes when I brake
My Steering Wheel Shakes When I Break. What would cause this t happen?
Old 07-18-2010, 07:47 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Steering Wheel shakes when I break
When was the last brake job? Normally excess lateral runout on the disc rotors meaning rotors could be warped. Also, worn out tie rod ends.
Timeslip 08/12/06
AF Community Guidelines
Old 07-18-2010, 05:03 PM
thanks
Old 07-19-2010, 06:26 PM
BNaylor's Avatar
Also, make sure the 5 lug nuts are torqued in a star pattern and each lug nut to 100 lb-ft with a torque wrench not an air impact driver.
Timeslip 08/12/06
Old 10-02-2010, 09:10 PM
oylchick oylchick is offline
Make sure you also check the tie-rod ends. If they have started to go bad you can get a vibration/shaking upon braking and should replace them ASAP.
300M steering wheel shaking and pulling right?. sandrav0312 300M 1 08-07-2010 04:47 PM
steering wheel shaking, pulling to the right uspres2020 Escort 6 10-10-2009 05:58 PM
Steering wheel shakes after new struts Oopey Camry/Camry Hybrid/Vista 2 08-03-2009 01:00 PM
Steering wheel shakes when braking 95_Grand_AM Grand AM 3 01-19-2006 12:38 PM
Steering wheel shakes when I brake NinjaPoweredAccord Tires and Wheels 5 07-16-2003 07:53 AM
