Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-03-2009, 11:02 AM
Oopey Oopey is offline
Steering wheel shakes after new struts
Had Meineke put new struts in a 1998 toyota camry (about 130,000 miles). When they replaced the struts, they broke the ABS sensor (which they then replaced for free). Since the replacement of the ABS sensor, the steering wheel shakes like crazy when going above about 55-60 mph. Any thoughts what might be wrong? Do I need to rebalance the wheels?
Tire pressure checks out fine. Tires were rotated a few thousand miles ago.
Thanks.
Old 08-03-2009, 11:15 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Steering wheel shakes after new struts
Take it back to the shop and have them fix the problem before your warranty expires...typically 1 month or 1,000 miles. The car should have had a wheel alignment after the struts were replaced, and they should have at least asked you if the tires needed to be rotated and balanced.
Other than that, potential causes of shaking/vibration at high speeds are usually worn ball joints and/or tie rod ends, and less commonly a worn steering rack. Get back to them pronto. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 08-03-2009, 02:00 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Other than making things right, don't go back to that place.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Tags
camry , shaking , steering , struts , wheel
