Old 04-25-2003, 05:18 PM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
emergency help....timing belt
ok so we tried to install a new cam we decided not to but thats besides the point so now the belt is loose, so we start by having it a TDC then following what chilton says we turned crankshaft 1/4 turn didnt tension the belt anymore than it was than it says retighten the adjusting bolt and thats already tight...l...what are we doing wrong someone tell me how to tighten a timing belt!!
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 04-25-2003, 05:26 PM
come on i need help and u guys suck right now
Say NO to Primer!!
Old 04-25-2003, 05:28 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
you took the t. belt off just the cam pulley? if so all you should have to do line the cam back up on tdc and slide the belt back on turn it 720 degrees counter clockwise to check it...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 04-25-2003, 05:33 PM
gunnmen01's Avatar
add me to yahoo or Aim...i have both running right now, ill help ya if i can...
gunnmen01
Old 04-25-2003, 06:00 PM
so belt is still too loose car runs fine but i cant drive it loose like this i dont want nothing too break,
Say NO to Primer!!
Old 04-25-2003, 06:20 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
i forget which was the tensioner move put, when i put my timing belt on, i pulled or pushed on the tensioner to get right of the slack in the timing belt. i used all my force, then i had my bro tighten it. got rid of the slack and yeah
Team Lonely Drivers
Old 04-25-2003, 06:43 PM
what do u mean...do u mean u tightened the 14mm bolt of the tensioner??????????
Say NO to Primer!!
Old 04-25-2003, 06:44 PM
oo and get this now we got it to tighten (the belt) and we thought it was tight and now the other side of the belt is loose wtf
Say NO to Primer!!
Old 04-25-2003, 08:43 PM
lorunner lorunner is offline
with the tensioner loose (the 14 mm bolt) turn the crank counter clockwise until the slack is taken up then tighten the 14 mm. if you cant get the slack out look at the tensioner if its at the end of its travel and the belt is still to loose then you may have the wrong belt, but I am assuming you still have the same belt if all you did was change the cam.
Old 04-25-2003, 09:07 PM
hmmm **runs outside to check it out**
Say NO to Primer!!
Old 04-25-2003, 09:21 PM
did you get lost
Old 04-25-2003, 09:28 PM
i give up for tonite, im sick of flippin hitting my hands on things when im trying to get bolts loose, i go from the top i hit my hand on the engine mount i go from the bottom i hit my hand on the crankshaft, so i cant get it loose right now so my boyfriend got me into this mess so hes gonna figure it out tomorrow(hes at work rite now) and he can get his hands all scraped like mine because its his fault anyway
Say NO to Primer!!
Old 04-25-2003, 09:32 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
ahaha, Thats the spirit.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 04-25-2003, 09:39 PM
branman_crx_guy's Avatar
branman_crx_guy branman_crx_guy is offline
Send a message via AIM to branman_crx_guy Send a message via Yahoo to branman_crx_guy
Plus workin when ur pissed off and tired is really just a waste of time. I remember me and my friend rob were puttin on my struts and coilovers on my car, its took 9 hrs!!! And we were straight through. By the time we were puttin the rear back together (3 am) it took us 45 min just to get one of the bolt holes to line up, its sucked so much ass i think i got hepatitus or some shit . But yeah, tomorrow you'll feel much better.
PS The reason it took 9 hrs was because we were tryin to figure out how to get the stock spring off the stock strut so we could use the parts on em, but we didnt have a spring compressor. We ended up having to dremel each one, lol...ah the ghetto fabulous life style, aint it a bitch.
PPS Hope i didnt offend anyone with my heatitus joke, i know its no laughin matter, but they oppurtunity was just sooo there.
Born 2/19/85: Thats right ladies, the BMan is Legal!! ;-)
Totallin My 89 CRX Si: +$2700
Buyin It Back From Insurance: -$50
Buying a 90 CRX Si: -$2200
Gettin to start over with more money and knowing i screwed insurance w/out trying: Priceless
It doesn't matter if you win by an inch or.........wait, thats been said already. On the road of life there are passengers and......no, thats been done too. Dang, all the good sayings have already been said, ohwell.
-BMan original
Old 04-26-2003, 08:52 AM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
speaking of hepatitus, my name refers to the standard model. However,
I know this post is about the timing belt but for those who wanna know.
To get stock springs off w/o compressors follow this:
1. disconnect shock from lower control arm
2. with jack under car, lower car to ground as far as you can
3. back inside car, undo the nut on top of the shock that holds the spring hat onto the shock all the way
4. slowly raise the car up which will slowly release tension off of spring.
5. now take off upper mounting hat from shock tower and remove strut assembly,
6. drink a cold beer and reflect on the goodness of ingenuity.
91 hatch Si
D16Y8 SOHC VTEC from 96 civic
ghetto short ram intake, HP Racing header, Sprint 1.5" springs, 15" Rota Slipstreams, 195/50/R15 Dunlop Sport tires.
Timing belt walk HELP! 91TSi_ Engine, Transmission and Drivetrain 13 10-15-2009 02:47 PM
Timing Belt kp055174 Accord/TSX/Accord Hybrid 2 07-27-2009 12:00 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
How to change timing belt? RainSpirit44 SVX 2 03-25-2009 04:30 AM
91 Metro 3cyl Timing belt help. Timing belt tensioner?..... doug2060 Metro 4 06-17-2008 10:40 PM
