Old 06-17-2008, 12:35 AM
doug2060 doug2060 is offline
91 Metro 3cyl Timing belt help. Timing belt tensioner?.....
Hello, I just replaced my front crank seal and put everything together but I am hearing an annoying sound from one of the pulleys. I believe it may be the timing belt tensioner. I may have put it on too tight (if possible). I slid the tensiner slider all the way. It went easily so I just assumed it was correct. Should I go back and loosen it?
Atleast it's not leaking oil anymore...
Old 06-17-2008, 05:14 AM
Re: 91 Metro 3cyl Timing belt help. Timing belt tensioner?.....
OK, I loosened up on the tensioner and the noise is gone. I did notice that when I tested it the timing belt would start to work itself off toward the edge of the pulleys. I didn't have the outer crankshaft pulley on when testing. It seems fine with the outer pulley on. Is this something to be concerned about?
Old 06-17-2008, 05:19 AM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Should be fine now. I overtightened mine at first also
Old 06-17-2008, 05:22 AM
Is it normal for the timing belt to work itself outward and the outer crankshaft pulley keep it in place?
Old 06-17-2008, 10:40 PM
I've been told that the belt walking off is common if the outer pulley is not on and that it keeps it in place. I just thought it may become an issue later.
