| Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here. |
#16
I'd take an Icon TT setup for my SS in a heartbeat, too bad they aren't being manufactured anymore...
2001 Camaro SS #2239 of 6332 1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276 307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC |
#17
Like this one..... :smoker2:
#18
11:1 comp ratio, no, 10:1 maybe. You could use thicker head gasgets, and if you have cash get the combustion chamnbers on the heads milled for lower CR.
Turbo kits for LS1's haven't really been perfected yet, at least i don't believe they have. The supercharger kits are a more popular choice. I think most of the kits are 6psi kits, which should be find with a stock bottom end, some are 9psi kits, which i guess is ok, but if you want your engine to last longer i'd stick to 6psi with stock internals.
'98 Firebird Forumla M6, Silver limo tint sides and rear, TR230/224, 3.73 gears, Hooker LT's , !CAGS, !FRA, ported MAF, direct flow lid, true duals with X pipe bullet mufflers and cats (dumps before the axle). |
#19
Thicker head gaskets wont lower you CR enough to make a difference. The only way to do it is to get dished pistons or different heads with a larger combustion chamber.
#20
Re: Blower-Supercharge-Turbo
Superchargers and 'Blowers' are the samething. Just thought i'd point it out... figured somebody had too
2003 Chevy 1500HD - Hauler 1971 Chevy Camaro RS - Track Car User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here. |
#21
And also, a blower and supercharger is the same thing, but generally when you say blower you're referring to a roots charger, and supercharger is used to refer to a centrifugal charger. Not my lingo, but THE lingo none-the-less...
There's no replacement for displacement...No, not even a turbo. |
#22
Of course you can go 9-12psi if your fuel system can handle it, but why not just lower your compression a bit as well as a forged crank and all. Also, i dunno about you, but i don't wanna have to worry about that 1 time you detonate and your engine is done for.
#23
#24
well im pretty sure you would be ok with a blower/supercharger or turbo.... i have a 76' maro with a 350. i have a 142 cid. weiand blower/supercharger. im running 5.45 lbs. of boost. i DONT have forged internals and its perfectly fine. i used the stock heads. but later upgraded to a set of aluminum heads. as long as you can run pump gas in your car now without any knocking or pinging then you should be good... i usually run 91 octane (gay ass california) with lucas octane booster. its totally fine. but u might want to up grade your distributor to a mechanical advance with an adjustible timing curve (MSD pro billit distributor) and you might want to get stage 2 cold spark plugs (to prevent pre detonation). if you have any questions regarding an installation on a blower then let me know and ill be more than happy to help you out and talk you through it. i pretty much ran into every problem you can with installing one. so i know how to fix almost everything.
#25
We don't need to be bringing back threads from the dead...Locked...
-Brian
