| Let's get Technical! Discussion for hardcore in-depth motor heads! |
#16
Re: Boosting an H22A
for the most part yeah..give or take depending on the turbo and the tune of the engine. But they will pretty much go hand in hand...you have to remember that in tech. terms the bigger tourque=bigger plant ..so it is hard for us to get alot of torque at the line due to out engine sizes...but 2nd gear is where the turbo would really be gettin its boogie on and you would start to generate alot more percentage of tourque, but at that point you are getting more and more into HP moving the vehicle because the main pull from still to speed has been made...remember tourque moves the car..HP pulls you there
#17
so i guess unless im revving the engine on the line and also have a damn good turbo, im not going to have much increased torque to pull the car off the line?
does anyone know where to get h22 cylindar sleeves?? cant seem to find them.
proud accord owner |
#18
have you checked the darton and golded eagle websites ???
#19
golden eagle rather
#20
What year is the h22a from. Check the head on the intake side and look for 3 circles. The middle circle will have 2 digits with a line in between it. Mine look like this 9|2, meaning 1992. If you have a 92-96 h22a, it has a solid deck on it which in that case all you would need to do is sleeve it. I don't believe the stock pistons and rods would be able to take 10psi on a sleeved block. If you are gonna sleeve it, might as well throw in some rods and pistons. H22's can take a lot of boost, don't believe the crap that they can't be boosted. They just have to be built to do it, but all honda motors are that way. 2 local guys are both running in the 20psi range and well over 500whp with their h22's. I will be in the same range when I'm done building mine.
93 accord - jdm h22a 2003 srt-4 - daily driver |
#21
to my knowlege i dont believe any of us said they could " never " be boosted...I and others have just said that you would need to build up the internals 1st, just as you stated before being able to boost it.
#22
Re: Re: Boosting an H22A
#23
#24
Thats nuts man, what did you do to the motor to get 260 hp out of it all motor?
#26
You can boost up to 7psi safely on a stock H22A. The weakest part about the block is the ringlands. If you resleeve the block and get forged pistons the H22A becomes more or less impenetrable.
![]() 1993 Mazda Rx-7 Touring Ricer Extraordinaire |
#27
whats a ringland? something to do with piston rings?? and if the engine was resleeved, would i have to get special sized pistons to fit inside the sleeves?
#28
If you got sleeves, yes, you would need new pistons. You can run stock bore pistons, or you can bore it out a few MM, whatever you chose there are a lot of companies that will make off-the-shelf pistons for you. |
