Go Back   Automotive Forums Car Chat > Honda > Accord/TSX/Accord Hybrid
View Poll Results: H22?
YOU MAY POST NEW THREADS 0 0%
YOU MAY POST REPLIES 0 0%
Voters: 0. You may not vote on this poll
Old 12-15-2002, 02:18 AM
rabalero rabalero is offline
Question h22
I HAVE THIS BIG QUESTION IM GOING TO SWAP A H22 INTO MY 91 ACCORD I HAVE THE ENGINE,TRANNY AND ECU.I WAS TOLD THAT ALL THE WIRING HARNESSES ARE THE SAME AND THEY ARE BUT I WENT TO THE WWW.H22.ORG HOMEPAGE AND THEY CHANGE THE DISTRIBUTOR TO EXTERNAL CAUSE HIS DISTRIBUTOR WAS INTERNAL BUT MINE IS INTERNAL SAME AS THE H22 I HAVE SO IS THAT OK? AND I WAS THINKING IF SOMEBODY HAVE THE WIRING DIAGRAM OF THE ECU OF THE H22 OR THE WIRING FOR MY F22 ECU??????
Old 12-15-2002, 11:14 AM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
Do youplan on putting an MSD on there? If so, don't sweat the internal to external, just get your MSD and put the external coil. I had the same thing happen and when my coil burnt out, we replaced it and it was almost 300 bucks, and then 2 months later I ended up putting and MSD on and found that it was just as easy to buy the external coil for 50 bucks and hook it up. So I kinda wasted money from the get go. I still have my internal coil, let me know if you still need one, if its the same one, I would be happy to sell it to you, as it just sits in my box of excess parts.. [email protected]. As far as the wiring of the external distributor, its too easy. The wiring of the engine and the ECU, it is helpful to have the pin-outs of the ECU, you can request these from Honda, it may cost a few bucks, but it beats guessing.. Good Luck
MY ACCORD ON KENWOOD'S PHOTO GALLERY
MY ACCORD ON CARDOMAIN
"CHEAP THRILLS"
I DON'T CARE HOW MANY SKY DIVES YOU'VE GOT. UNTIL YOU'VE STEPPED OUT INTO COMPLETE DARKNESS AT 850' WEARING 95LBS. OF EQUIPMENT AND 68LBS. OF PARACHUTE. YOU JUST HAVEN'T LIVED.
ARMY AIRBORNE!!!
H22 motor w/ h23 trans||h23 wired for vtec? ||h23 2 h22 any ac problems?||H23 axles o sprayedlude93 Prelude 9 12-03-2004 12:07 PM
All motor H22 vs H22 turbo? JDMugenKid Let's get Technical! 6 01-30-2004 11:32 PM
How tell a JDM H22 or USDM H22 mast0075 Engineering/ Technical 8 12-17-2003 11:45 PM
V-spec h22 vs Jdm h22 type s prelud-a-cris Engineering/ Technical 4 10-23-2003 09:29 PM
orderin an h22 off net....which place is best to get the h22 from Atariallstar Engineering/ Technical 11 10-10-2002 09:54 AM
