| Latest | 0 Rplys |
Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
#1 | |
Hi,
last week I got my issue of the R5 Maxi, the Chatriot-Perin TDC 1986 version ![]() ![]() Having an extended look ![]() Resin parts Main parts are the body and chassis. The body is done in correct dimentions, all panel lines are correct and deep enough. The resin is of great quality, no holes or bubbles that need filling on both parts. Around the window there is some thin resin excess, that needs to be sanded down, the same at the opening around the rear and front bonnet, but this shouldn´t be a bigger problem. ![]() ![]() ![]() The same for the chassis, good quality resin on the visible parts, a little bit of sanding, and both parts should be ready for primer. ![]() ![]() The two bonnets have hinges of resin, already fixed to them. They are durable, when these hoods are often moved, but the modeller has the option, to replace them with etched parts, what is more to scale and accurate. With minimum cleaning of the bonnets they should fit in their openings, while on the rear one there are some holes to be filled. The two openings on the rear bonnet´s roof should be drilled out. ![]() ![]() Engine and dashboard are done in crisp resin, on the engine the holes for the spark plugs are already opened !! ![]() ![]() ![]() ![]() Here all the other Resin parts ![]() Wheels come in 2 different sizes (front and rear) and need a little time to be cleaned from thin resin excess between the fine spokes. ![]() Engine parts like turbo etc. look great and will look the engine outstanding with colour and some wiring. White metal parts Well, no problems to see. The cage, brakes for front and rear (2 seizes) fire extinguisher, steering wheel, shifter, parts of the steering, reservoirs for diverse liquids, etc. etc. Lots of parts !! ![]() ![]() Other materials I must admit, that when I opened the box and looked over the parts, my first thought was: “Damned ![]() ![]() This should work well, as there is an etched frame for the windscreen, to hold the acetate down, which isn´t totally plain here. Making the sliding windows in the doors will need some careful work. 6 slick-tires are in the kit, 4 for the car, 2 spare tires. They are made of black resin ![]() ![]() ![]() Clear parts come for the lights and a bottle in the engine compartment, seat belts are made of fabric and a vacu-formed part is used as a radiator tray. One of the 6 round glasses was broken ![]() ![]() ![]() ![]() Decals are printed sharp, nearly no clear surrounding to cut away. Together with the added base-colours (!!) from Zero, they should make a good looking body. ![]() ![]() ![]() So, last but not least, the etched parts. Very much parts ![]() You can chose between white metal brake and clutch padal, or you use several etched parts, to build them ... ![]() The straps ![]() Pedals, hooks, … ![]() Radiator, grill, … ![]() ![]() Seatbelt hardware ![]() Instructions come in a little booklet, giving tips for colouring etc. ![]() ![]() So, what conclusion at the end ![]() A first kit from a new company, what makes a little suspicious ![]() But: very good quality resin and white metal parts, lots of etched parts, main body colours makes the kit outstanding ![]() ![]() So I´m looking forward to see a. some WIPs of this kit and b. the next kit of Scuderia Italia.Lab ![]()
Micha ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#2 | ||
Re: R5 Maxi Turbo Gr. B by Scuderia Italia.Lab - Kit Review
Hi,
very nice kit review, the kit seems to be really worth his price. Quote:
![]() Greetings, Jens |
#3 | |
I may be biased but I think the kit looks outstanding
![]() Subject is awesome, the detail in the resin parts looks excellent, the Cartograph decal speak for themselves, the addition of paint to the set is groundbreaking (question of shelf life?) and that p/e fret is kit in itself!! (BTW 16 pieces for racing harness is about par for the course in my limited experience) I agree with you that an alternative to resin for the tires would be better in future. The headlight lenses are the only real question mark in my mind after looking at the photos. So Micha, when do you start your WIP? ![]()
Guideline for happy modeling: Practice on scrap. Always try something new. Less is more. "I have a plan so cunning, you could put a tail on it and call it a weasel" - Edmund Blackadder |
#4 | |
Wheel lug patterns are way off on all wheels. That really caught my eye. But not anything that couldn't be fixed. I really am not at all interested in this timeframe of rally car but I am interested in the kit. This thing looks absolutely superb! I can tell that Gio and his accomplices spent many an hour on all of this. I mean what other kit can you get awesome resin casts, white metal casts, Cartograph decals, great instructions, tons of PE, and even top quality paints in one shot?! This is gonna be in my hands soon I am thinking.
Great job to Gio and his friends!!! |
#5 | |
Indeed kit looks great!
Zeljko Segin http://www.hrmodeler.com - Fast wheels - my pages My current project - ..... ![]() |
#6 | |
I must admit I am truly amazed with quality of this kit. Gio did you try any known tires that could fit instead of those resin ones?
#7 | ||
Authorized Vendor
![]() @ Steve: you'll see when you have in hand: TBH they're the best resing transparents I seen in a MM kit: we had to try several manufacturer until we found that. @ Sasa: no matter, the're good: for sure for the Clio we have vinil tyres since there're already in the market tools done, we have just to ask casted copies. For the R5 the final cost per kit would be approx 15-18 eur more or so since we need to pay the metal molds ( two, and I'm talking of hi-quality rubber, think at Hiro level or some slot stuff). But my opinion is that is just a marketing problem: black resin tyres are really great, with a couple of touch awesome, and you'll simulate the car's weight sanding a bit... you'll see at naked eye.
#8 | |
I have my 1985 TdC version at home.... This kit is the best, what I have in my hands (sorry friends from REJI model).... Looking to Audi :-)
#9 | |
Gezus G
![]() This kit of yours looks awesome. ![]() One of the best Multimedia kits I have ever seen. And the car is a little beast too. It's a shame the wife beat me up today over the size of my kit collection... ![]() ![]() Nens
#10 | ||
Authorized Vendor
![]() ciao! gio
#11 | ||
lots of this to do besides modelling, this week I wasn´t working more than an hour on my Hayabusa, and there is another Rallye Car on the bench ....
#12 | ||
Authorized Vendor
#13 | |
Great review Micha!
And great model Gio! ^^ Agreed with Big Kahuna: One of the best multimedia kits i've ever seen!! The quality is outstanding!! ![]() [But i'm really interested in that Clio...Hmmm ![]()
![]() "Oh noez,it has more stickers than me! And a wing too! ![]() ![]() |
#14 | |
Image Hosting Exceeded
![]() Join Date: May 2003
Added to the Review section (along with a bunch of other misplaced reviews!).
I'll add my own opinions, just as soon as I get one! (Mine got turned around and sent back to Italy by customs!!) ![]() ![]() ![]()
PHOTOBUCKET SUCKS |
#15 | |
Did I see correctly, a 1/24 Clio Maxi is on the way?
... Sorry there, I think I fainted for a while. That car is in my top 5 of all time favorites. Were will I be able to order one, when it comes out? |
