Our Community is 662,000 Strong. Join Us.
View Full Version : Celica
Pages : [1] 2 3 4 5 6 7 8 9 10 11
  1. Celica Oil Comsumption
  2. why is my gas going so fast!!!!
  3. help with cold start
  4. fitting a turbo to my 1995 celica
  5. Lighting gremlins
  6. 90 Celica timing camshaft & crankshaft?
  7. 90 Celica Timing belt R & R
  8. 1988 Toyota Celica GT Convertible Parts
  9. 90 Celica no fire out of coil
  10. 91 Celica GTS Rear Suspension Arms
  11. 90 Celica misfire
  12. 5sfe question
  13. my engine build. its been afew years since ive posted on AF
  14. 94 celica base strut question
  15. Toyota celica 2000 GT, bad ECU?
  16. new alarm remote, need help finding ecu please help
  17. Any information about this 93' Celica STX Turbo? (with pictures) Advise, help
  18. looking for
  19. side marker
  20. Will this work?
  21. 82 Celica choke voltage
  22. 7AFE can I use 4AFE Celica Engine
  23. 96 Celica Engine pull for replacement.
  24. 2002 gt center engine under cover necessary?
  25. Wheel interchangability 2001 Toyota Celica GT
  26. Celica Reverse Sound. 2nd and 3rd Gear also help!!
  27. 1983 Toyota Celica Doors
  28. 93 Celica Drive Shaft
  29. 3 sfe long v short block
  30. 1992 Toyota Celica GT Oil Leak Question
  31. Car Goes Click, Click, Click
  32. CHALLENGING ALL MECHANICS to figure out this problem
  33. Sounds while turning at slow speeds
  34. How to program car remote for Celica 1997
  35. 01 celica lacking power
  36. 2jz
  37. oil leak
  38. car starts but turns off after 5-10 min
  39. going manual
  40. new 5sfe will not start?
  41. Turbocharging a 5sfe
  42. ecu
  43. How to replace headlight on 1994 Celica ST?
  44. fuel system wiring diaghram
  45. 114k Miles too much?
  46. 1985 celica jdm parts???
  47. 3vz-fe powered celica 5th gen....my conversion
  48. speeding up a 97 ST?
  49. Front speakers on my 97 celica st don't work. any tips?
  50. looking for 5sfe for my 97 celica?
  51. Need Advise Please
  52. 03 celica GT auto trans problem
  53. Carlos Sainz Hood?
  54. 90 Celica ST Need mod help
  55. 03 celica gt high idle
  56. Flowmaster 80 Series?
  57. help me out with my 00 celica gts
  58. What motor???
  59. Celica steering pump and rack replacemnt cost?
  60. 85 toyota celica GT 5mge swap
  61. celica gt 2001
  62. Big Time GA Meet June 2010
  63. How to add a a director to a company
  64. Replace rear struts on 91 celica
  65. 2000-2005 oem headlight
  66. rear bumper for sale
  67. aftermarket taillights for celica for sale
  68. oem 2002 celica tail lights for sale
  69. 1991 Celica GT - Electrical Help Needed.
  70. 1994 celica, 2200, acceleration
  71. Continental Headlights GT4 ST205
  72. Needing your HELP!!!
  73. 1997 celica squeal
  74. 95 celica gt rattle
  75. 98 convertible window motor
  76. 2000 Celica GT-S VS Scion tC?
  77. Celica ST
  78. Super strut suspension non adjustable?
  79. 1990 Celica Gauges
  80. help
  81. electrical :( 2000 GT-S
  82. Bad 2000 GTS Issues :(
  83. Finally Have a GTS!
  84. Swapping Motor From 94 to 91 Celica GT ?'s
  85. gts compatible?
  86. Stick gas pedal
  87. B0106/54 code after replacing air bar hardware
  88. 86 Celica Gt suspension problem?
  89. Gen 5 Rear Seating
  90. 2000 Celica GT-S
  91. Lack of power when cold!!
  92. 1993Geo 4AFE in my 1990 cellica st?
  93. celica bodyrot
  94. gidday guys. questions about 3sgte
  95. 93 Celica...
  96. 2000 GT, Need your wisdom
  97. Help a n00b=(
  98. Used Parts - Best place to find?
  99. 22re to 2zzge motor??
  100. Cooling/heat issue/s :/
  101. exhaust systems?
  102. Celica makes creeking noise
  103. How much could i get from parting my 79 celica?
  104. 2000 GTS Idle issue
  105. 90 Celica Brake lights on when turn on headlights
  106. 2002 Celica LONG CRANK
  107. CELICA MK5 Electric problem - HELP
  108. Need helps!
  109. 94 celica 1.8 7afe motor. mod it or swap it?
  110. 1zz engine swap
  111. losing power
  112. 95 2.2 Celica just quit. Timing,fuel,Spark all OK
  113. 02 celica electric door locks locking & unlocking by there self
  114. engine teardown
  115. 1982-85 chassis colors
  116. Opinions...
  117. Power Steering Leak Question
  118. 94 windshield
  119. Help for a noob
  120. 15,000 miles and strong
  121. '99 Celica, falls on its face
  122. Big Bore TB Help
  123. fuel problems 92 celica
  124. 7mgte
  125. A couple weird things going on.....
  126. A couple weird things going on.....
  127. 1990 Toyota Celica Running Issue
  128. 3sgte?
  129. Celica/Supra Transmission
  130. 92 Celica GT 5S-FE - No Spark
  131. Stalls / Idles low when AC is on
  132. Still learning
  133. Help
  134. 1998 celica
  135. Need Help On My '92 Celica St
  136. 1983 GTS Celica ALternator CHarging Issues *HELP*
  137. first car
  138. 04 celica gt... going turbo need help....
  139. Need Advice on Suspension of a 90 GT-S
  140. more tranny trouble
  141. Problem now?
  142. I need help
  143. Transmission markings
  144. 91 celica tranny trouble
  145. about alignment
  146. looking to get in to a celica
  147. 87 Celica- timeing problem?
  148. 5sfte!!!
  149. 94 celica gt bolt ons
  150. 1987 Celica ST
  151. 0-60 times 2001 celica
  152. just bought a 88 celica GTS now wut???
  153. 1987- drivers seat stuffing?
  154. 02 Celica Gt
  155. 79`gt,need Help!!
  156. Small SoCal Old School Celica Meet Up
  157. exhaust pipe
  158. Almost done!
  159. Diff Advice
  160. electrical problem - 2000GT
  161. OIl leak , engine in trouble?
  162. 91 st head
  163. 2000 celica engine?'s
  164. IAT Sensor Location
  165. Jerking Problem 1990 celica Gt
  166. need some help with my 94 celica
  167. 86 celica turbo
  168. 86 celica turbo
  169. 2003 celica 1.8li NO GAS!
  170. 2000 Toyota Celica GT-S Need help!!!
  171. 91 Celica Tail Lights
  172. knock sensor location
  173. Rotors Installation
  174. beef up tranny
  175. Engines 99 celica?
  176. front end knocking and wobbly steering problem
  177. Rack and Pinion 91 Celica
  178. 88 alltrac project car need advice
  179. Help..!
  180. '90 - '94 ECU Tuning
  181. just got new clutch, have a question
  182. [1994 Toyota Celica GT] how do i get the best performance without turbo or super?
  183. RC Front Lip
  184. Help Please!!
  185. 93 - 1.6 cold hesitation and bucking, need help!
  186. location of fuel filter and fuel pump?
  187. Need Vin # info
  188. Rear quarter damage?
  189. 91 Celica Power Steering Belt replacement
  190. 1990 Celica GTS cooling system
  191. 1990 celica gts hatchback VALUES
  192. t3 celica project
  193. 1990 celica gts hatchback suspension
  194. speed to RPM ?
  195. Panasonic Rear End Crash
  196. Enigine Swap
  197. 1990 Celica GT-S half shaft seals
  198. Brake drums removal
  199. looking for a project
  200. Ever See A 77celicasupra 2jzgte Twin Turbo
  201. 1972 Celica project
  202. questions about swap
  203. Need some help
  204. Question about rims
  205. Help please ; Toyota Celica or Toyota Supra
  206. 01 Celica gts shifting problem
  207. Urgent
  208. Accelerator Cable
  209. 4agze swap into 91 celica st
  210. Nos?
  211. Celica VS camero
  212. 1990 Celica ST Suspension options?
  213. 00 Celica 4 speed automatic
  214. 4th gen slightly high idle problem
  215. hay all
  216. 87 celica auto to transmission
  217. 3SGE header on 5SFE?
  218. 1990 Celica GTS surging after warm up
  219. 1ZZ-FED (2000 celica gt) vs 1ZZ-FE (2004 corolla)
  220. Tire selection for 02' Celica GT
  221. 96 celica gt four parts
  222. 96 toyota celica gt with gt four parts
  223. Oil Pressure gage help?
  224. Kenwood head unite
  225. Does anyone know anything about the 5AFE engine
  226. Need Help with Celica ST 89
  227. Swap 1JZ-GTE
  228. Replacing a lowbeam headlight on a 6th generation Celica
  229. please help
  230. 2002 Celica GT Auto Tranny Stuck
  231. 2002 celica gts is this woth it
  232. stupid air conditioner
  233. Bought celica, tiny problems.
  234. Mr2 lsd tranny fixed but....
  235. How many miles do you have on your 91 Toyota?
  236. Cruise Control Problems...
  237. NEW Gas tank? - 1991 celica
  238. Trying to remove a mangled brake line
  239. Coolant bleed screw location 2000 Celica
  240. The Right Car
  241. 86 Celica GTS - Small yellow door clip?
  242. help on 91 celica o2 sensor
  243. Rebuild of front end help
  244. 87 gts aftermarket help
  245. Overheating...help!
  246. Wich is the best celica
  247. Accelerating problems! pt.2
  248. BRAKE LIGHT FUSE ERROR. any help?
  249. BRAKE LIGHT FUSE ERROR. any help?
  250. Steering wheel
